EAGLE User Support (English) Eagle brd and sch file format specification
  • Replies 10 replies
  • Views 3793 views
Whats the deal with the BRD and SCH file format specification?
Are they described anywhere?
I am working on a content manatgement system for a client of mine, and they
would like to be able to view, but not edit, BRD and SCH files right inside
the content management system. The machines running the CMS will not have
Eagle installed on them.
Is the file specification publicly available, or even available via NDA ?
-Kenny
    autodeskguest over 17 years ago in reply to autodeskguest
    Rikard Bosnjakovic wrote on Mon, 25 May 2009 02:19
    Tilmann Reh wrote:
    EAGLE has very powerful export capabilities by use of ULPs, you can
    generate about any format you desire. This is all you can get.
    FWIW: I have never - never - managed to read any Eagle exported data
    into any other application. In particular I've been trying real hard
    with
    netlists, but no application can read Eagle's output, and I have never
    managed Eagle  to read any data exported by other applications.
    So I'd gently resent "powerful export capabilities", because that
    statement is anything but true.
    Hello Rikard,
    The default netlist export of EAGLE isn't any particular standard.  It's
    easy to read if you are trying to do hand verification.  But I don't think
    CadSoft ever intended it for inter-tool communication.
    My company has a PADS netlist import/export tool.  I've personally used it
    with success in both directions.  You can export a PADS netlist from an
    EAGLE schematic and import into a PCB layout tool.  Or you can create your
    schematic in another CAD tool and import the PADS netlist you get from it
    to use EAGLE as the board editor.
    Cheers,
    James.
    email:  sales2009@eaglecentral.ca
    fax:    888.701.8097
    web:    http://www.eaglecentral.ca
    Online EAGLE Dealer for US and Canada
    EAGLE Design Experts
    EAGLE Enterprise Toolkit
    into any other application. In particular I've been trying real hard with
    The netlist (and other "direct" exports) use plain ASCII files, human
    readable. I would never expect any other software to be able to import
    these directly.
    By use of ULPs you can generate any format and any content you desire.
    If you need a format that is not yet available: write your own ULP. By
    using ULPs, you have full access to the /complete/ design information.
    I assume you didn't think of ULPs when you wrote that. Perhaps you are
    not used to them.
    Tilmann
  • nickds1
    nickds1 over 17 years ago
    "Yaroze" <KennyMillar.kennymillar@mac.com> wrote in message
    news:gv3hqh$32n$1@cheetah.cadsoft.de...
    "Nick de Smith" <nick@desmith.net> wrote in message
    How about printing them to PDF and viewing that?
    Well, we can't do that with just the .BRD and .SCH files, and no copy of
    Eagle installed!
    Nice idea though.
    We are talking at cross-purposes - the person producing the brd/sch files
    with Eagle also produces the PDF for each when they place them in the CMS -
    Eagle V5 has a PDF "printer" built into File->Print... for free.
    So, the CMS contains the SCH-PDF, BRD-PDF, SCH & BRD, but only the PDfs are
    viewable as pretty much any CMS can view PDFs... The trick is to ensure that
    the PDFs always reflect the latest BRD/SCH - In a previous life we used to
    do this by using command line options from a scheduled job every night to
    execute the print command - if you print to a file with a PDF extension,
    Eagle will generate the PDF for you.... Have a look at the online help...
    Cheers
    Nick
    Paul Romanyszyn schrieb:
    Tilmann Reh wrote:
    Maybe it's a solution to
    install the freeware on one of the CMS machines and automatically run
    the needed ULP(s) on that to generate the data for your CMS?
    Also the Eagle demo license allow all cam and ulp's to run. It just
    restricts moving parts outside of the limit area.
    That's exactly what I meant.
    Tilmann
    our CMS here uses pdf's as the master documents, but each version record
    can also attach native CAD ( ie .brd, .sch) files so one can work from
    an old version if necessary. it seems to be a good system.
    i expect attaching gerbers would also be useful if they are what you
    send to your manufacturer. then nobody needs to read the EAGLE files
    unless they want to fork the development of the board for some reason or
    copy an old layout, etc.
    I think that's what is called "proprietary information". You'll hardly
    get any internals/details.
    I understand that this doesn't help you much in this case, since you
    need EAGLE installed for running the ULPs. Maybe it's a solution to
    Tilmann
    Paul R.
    Tilmann
    news:gv3gqe$t0t$1@cheetah.cadsoft.de...
    news:gv3c89$61m$1@cheetah.cadsoft.de...
    they would like to be able to view, but not edit, BRD and SCH files right
    inside the content management system. The machines running the CMS will
    not have Eagle installed on them.
    Nick
    Eagle installed!
    Nice idea though.
    -Kenny
  • nickds1
    Nick
