EAGLE User Support (English) The directory doesn't exist!
  • Replies 10 replies
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 2077 views
The directory
L:\Projects\Switch\V2\%systemdir%\System32\eagle
doesn't exist!
BlaBlaBla
Create it ?
That happens everytime I open a .sch or .brd
If I click Yes (to create the goddam folder), it creates a folder next to the project files with the same structure written in the message (and notice the weirdnessness of the path)
If I click no, then the program gets evil and full of error message, from opening upon closing of the program, like always asking me to update eagle (it doesn't remember my choice)
Or, if I set Options>Directories, it won't memorize this dir next time I open, or the color I've set to the background
And so on..
What's wrong here ?
I, in my humble knowledge, suspect that's something related to environment variables or registry (?)
It's a recently formatted PC
Eagle 7.2
    RESOLVED
    The System and User environment variables were incorrect
    Home and HomePath must be C:\Windows\System32\
    SystemRoot must be C:\Windows\
    0 e14 Contributor over 11 years ago in reply to autodeskguest
    I do, like Warren, not use the $Home.
    On installation I deny the creation of directories.
    After installation is finished, in control panel /options /directories I
    enter the paths I want.
    Joern Paschedag
    That makes us three people that customize things on the proper time
    That makes us three people that do not use the $Home
    The installation does not ask me to adjust directories. The only question it makes is about license.
    And even if I do change the directories manually, it will not remember next time I open eagle, because of these problems that are occurring
    Tell me,
    Should I change anything else besides the Projects directory ?
    0 autodeskguest over 11 years ago in reply to autodeskguest
    Am 16.05.2015 um 22:04 schrieb warrenbrayshaw:
    On 17/05/2015 5:07 a.m., Lucas Silva wrote:
    The directory
    doesn't exist!
    BlaBlaBla
    Create it ?
    open
    And so on..
    I would guess
    (1) The $Home variable is at play here. Read the manual regarding
    behaviour and use of the $Home variable in Windows.
    (2) Your Options > directories is missing a semicolon between two paths.
    Personally I don't leave any reference to the $Home variable in the
    HTH
    Warren
    Joern Paschedag
    0 e14 Contributor over 11 years ago in reply to clem57
    I've tried Browsing the desired folder.
    After setting, Eagle erases it upon closing of the program
    I've tried cleaning the Projects directories before Browsing the desired folder
    Same happens
    I'll repeat here the message that appears when I launch the program (not through a .sch or .brd this time, whether they are similar):
    The directory
    E:\Program Files (x86)\Cadsoft\Eagle 7.2.0\%systemdir%\System32\eagle
    doesn't exist!
    I wonder if this strange %systemdir% thing has anything to do at all with the path that I store my projects
    • Eagle is installed on E:\Program Files (x86)\Cadsoft\Eagle 7.2.0
    • My projects are in L:\Projects\
    Here's how my PC looks like
    %SystemDrive%
    C:
    %SystemRoot%
    C:\WINDOWS
    %WinDir%
    C:\WINDOWS
    %HomeDrive%
    C:
    %HomePath%
    %systemroot%\System32\
  • clem57
    0 clem57 over 11 years ago in reply to clem57
    Oh do not delete any setup information. Eagle stores things there and will try to recreate if missing his items.
  • clem57
    0 clem57 over 11 years ago in reply to e14 Contributor
    I tried an experiment. I used the browse button in middle to go to my desired folder and it setup exact direct directory without the %systemdir%. Can you try yours to verify?
    Clem
    From the manual:
    On Windows the value of $HOME is either that of the environment variable HOME (if set), or the value of the registry key "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\Personal", which contains the actual name of the "My Documents" directory.
    I forgot to tell, but I'm not using $HOME
    The only path I keep trying to insert on Options>Directories is the absolute L:\Projects\
    Nothing else
    But it erases upon closing
    The directory
    doesn't exist!
    BlaBlaBla
    Create it ?
    open
    And so on..
    I would guess
    HTH
    Warren
    Clean unistalled, Scavenged for remainings (few on the registry), and Reinstalled
    Did not work. Same behavior.
    Clean install of Windows 7 SP1 plus updates
    C is Windows
    D is stored stuff
    E is where the heavy programs are (like E:\Program Files (x86)\CadSoft\Eagle)
    L is all my projects
    All of those are HD partitions
    When I echo %systemdir% it responds with %systemdir%
  • clem57
    When you formatted PC:
    1. did you install new Windows and what version?
    2. Reinstall Eagle?
    3. What is value of environment variable %systemdir% Use terminal and echo %systemdir%
    4. L: is not normal C: drive. What is it? removable?
    Clem
