    • Avnet Boards Community
EAGLE User Support (English) Open Sch & Brd files together
  • Replies 72 replies
  • Subscribers 180 subscribers
  • Views 7190 views
k.portman
k.portman over 15 years ago
Is there a way to open an existing Sch & Brd file together, by default.
When I double click either Sch or Brd file name on the Eagle Control
Panel it asks "Do you also want to load xxx.brd?" (or xxx.sch). I always
respond Yes, sofar never had a need to respond No.
Is there a eaglerc.usr setting to force (or make as default behaviour)
the opening of Brd & Sch files together. If not, could it be
implemented. Much requested for!!!
Kim
    autodeskguest over 15 years ago
    Silviu Epure schrieb:
    And to be usefull. Eagle Control Panel should at least support pdf and
    images....Could be displayed/preview on the "white (now - 90%of time) area
    of the Control Panel"
    I strongly disagree. EAGLE is a PCB CAD software, neither a file manager
    nor a PDF (or whatever else) previewer. For such purposes, other tools
    exist.
    Tilmann
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:hm5m69$us8$1@cheetah.cadsoft.de...
    area
    exist.
    Tilmann
    I somewhat agree with you:
    developper time should be used to evolve electronics part of the eagle, not
    minore things like that
    exist.
    Tilmann
    EXACTLY!
    Gruß / regards
    Joern
    exist.
    True, but Eagle does not have, nor intend to implement a simple interface to
    this type of documents.
    Please remember that ALL your electronics projects are basen on at least one
    PDF file......
    It's called "documentation", it's the most important part of a project, and
    Eagle has no support for this.
  • dukepro
    dukepro over 15 years ago
    On 02/25/2010 02:16 AM, Tilmann Reh wrote:
    Alexander Horst schrieb:
    Often, there is no epf, e.g. when opening a sch&brd pair, which was sent
    by email. In this case I very often run into the behavior as described by
    Silviu.
    This could be solved if EAGLE would load some kind of default "project"
    settings when a sch/brd file is opened directly (instead of a project).
    Tilmann
    Alexander & Tilmann,
    All very good points.
    A checkbox in the dialog "Always do this" would be rather simple to add.
    To initialize this, add an entry in ~/.eaglerc.  Perhaps something like:
        Dialog.OpenMatchingFile = {"Always","Never","Ask"}
    would work, with the absence of the line defaulting to "Ask"?  To revert
    the choice, all one would have to do is delete that line or set the
    value to "Ask" using a garden-variety plain text editor like vim or
    emacs (I'm a vim-guy myself).  By keeping this in ~/.eaglerc, it remains
    the choice of the user and does not affect others who might use the same
    installation.
    The fact that this thread boasts such a robust debate indicates that
    there is diversity of need.  As such, if I were on the design committee
    at CadSoft, I would at provide the user the choice and not mandate
    that the matching sch/brd always or never opens.  While there are
    clearly those who want to always open the matching file, there are also
    those want the option, and those who would choose "never".
    The task of predicting how one's software will be used is daunting to
    say the least.  The wider the customer base, the more configurable
    options have to be present, and documentation thereof, to accommodate
    unforeseen uses of the software.
    Enjoy,
        - Chuck
    Chuck Huber wrote on Thu, 25 February 2010 09:31
    committee
    Think about it from the newbie perspective.  They may not understand the
    full issues about opening both files together or not, and asking them will
    give the impression that either is reasonable.  Not opening both files is
    dangerous and not something anyone will want to do often.  It should only
    be done by those knowing exactly what they are doing.
    Therefore there shouldn't be a choice or at least it should default to
    silently opening both.  For the rare cases where a expert user really wants
    just one open, it's easy enough to close one of the two.  However you've
    prevented people getting themselves into trouble in the normal and far far
    more common cases.
  • k.portman
    more common cases.
    Fully agreed. I think that a new option in the eaglerc is the best
    alternative sofar. As there has been also other options added lately via
    the eaglerc (like ctrl-right-click behaviour), should be a valid way to
    do it.
    I would also propose to make as default to open both brd/sch together,
    would make newbie users life simpler and safer. Those who have had to
    repair broken sch/brd file contents (suppose all posters on this thread)
    know that it can be a daunting experience.
    Kim
    PDF file......
    No, it doesn't, but so what? How often do you use that swiss army knife?
    It does a lot, but none of it well, don't you usually break out the real
    tools? Do you really want Eagle to be that way? It will be if the
    developers spend lots of time on non-Electronic stuff.
    A file manager is for viewing files, and whatever document creating
    software is for creating documents, and Eagle is for designing
    Electronics. I don't want a swiss army eagle.
    I don't know why some of you organize your files the way you do....
    Here's what I do and it works quite well:
    Top folder: c:\Projects <--This is the directory Eagle Projects points to.
    Subfolders: Project NameA, Project NameB, Project NameC
    Subfolders for each project: Hardware, Marketing, Software, other
    project specific folders that doesn't belong in any subfolder
    Subfolders for ProjectName->Hardware: Datasheets, Firmware, Schematics
    Subfolders for ProjectName->Hardware->Firmware: If project has multiple
    boards that need firmware, Name of each Board, i.e.: Sender, Receiver.
    Otherwise this level is skipped and go to the next line:
    Subfolders for ProjectName->Hardware->Firmware->BoardName: v1.0, v1.1, v1.2
    Subfolders for ProjectName->Software->Schematics: works same as
    Subfolders for Firmware, but under each version number is CAM output for
    gerber files. Each v1.0, v1.1, v1.2 folder is an eagle project folder.
    There may be multiple brd&sch pair files in each version folder if there
    are multiple PCBs for that project.
    Subfolders for ProjectName->Software: Releases, Source
    Subfolders for ProjectName->Software->Releases: v1.0, v1.1, v1.2
    Subfolders for ProjectName->Software->Releases->Ver#: Release for Web,
    Release for CD
    Subfolders for ProjectName->Software->Source: v1.0, v1.1, v1.2
    Subfolders for ProjectName->Software->Source->Ver#: Help, and a folder
    for each project of the software
    Changelogs for each component are kept in the version # folders (v1.0,
    v1.1, etc.)
    Very organized, easy to backup, and takes care of revisions. It also has
    the advantage that you can browse every project from the eagle projects
    folder. And therefore, I LOVE that eagle doesn't show non-eagle stuff!
    It would make browsing several projects at a time a NIGHTMARE of
    scrolling if it did. It's already bad enough due to the Libs and how
    long they get...
    Note that the only thing this doesn't do is indicate which versions of
    firmware / software are fully compatible with one another, but usually I
    try to number all version numbers the same, and list those changes in
    the documentation.
    Travis
    Travis G wrote on Thu, 25 February 2010 13:29
    I totally agree.  I want CadSoft concentrating on making electronic design
    with Eagle better.  I already have plenty of other tools to help me write
    documents, edit firmware, etc.
    I do it even more stripped down in the Eagle directory.  Basically, I only
    keep Eagle stuff in the Eagle tree.  I keep my own eagle directory, which
    is separate from the Eagle installation directory.  The Eagle installation
    directory is only for stuff that comes from CadSoft.  All my own stuff goes
    into my own Eagle directory, and all the search paths for ULPs, libraries,
    etc, only look in my own eagle directory.
    One of my eagle subdirectories is "proj".  In there are directories for
    each separate customer.  Inside those are directories for each separate
    board.  I use a whole directory for each version of each board.  That way
    schematic, board, gerber, drill, drawing, BOM, and other files for a board
    are nicely in only one place and there isn't non-board stuff there
    cluttering things up.  There is rarely a nice one to one correspondence
    between boards, firmware versions, host programs, etc, so only
    board-related stuff goes into the board directories.  Firmware, host code,
    and documentation live other places in the system and have different
    organization.
    Only Eagle stuff lives in the eagle tree.  This makes the Eagle control
    panel actually useful for exactly what it was intended for.  I've never
    wanted to open a Eagle file other than thru Eagle.  CTRL-ALT-C (my own
    Windows hot key mapping) opens Eagle in a split second, then I can quickly
    and easily open whatever from there using the arrow keys and ENTER from the
    Eagle control panel.
    I think people would have a easier time with Eagle if they tried to embrace
    it for what it is and use other stuff for what it isn't.  There are way too
    many ways someone could set up their own workflow and structure, and it's
    not reasonable to ask Eagle to accomodate them.  Eagle does what it does
    well.  Fit it into your workflow as it was meant to be.  Don't try to
    modify Eagle to handle your workflow, because there will be a never ending
    list of things CadSoft would have to do to appease everyone once they start
    down this slippery slope.
    My projects folder is also my own eagle directory; in it is none of the
    Eagle supplied libs or ULPs. Those all reside in the Eagle program
    directory.
    In my projects folder I also keep a subfolder called Eagle that I didn't
    mention earlier. In that folder are subfolders for all my ULPs and libs
    I've created.
    I see the benefit of keeping some of it separate from the projects
    folder, as you do, but I do it my way for easy backup. Also if I ever
    implement a professional CVS such as subversion, it will keep track of
    everything by tracking only 1 folder.
    Travis
