    • Avnet Boards Community
EAGLE User Support (English) Open Sch & Brd files together
  • Replies 72 replies
  • Subscribers 180 subscribers
  • Views 7203 views
k.portman
k.portman over 15 years ago
Is there a way to open an existing Sch & Brd file together, by default.
When I double click either Sch or Brd file name on the Eagle Control
Panel it asks "Do you also want to load xxx.brd?" (or xxx.sch). I always
respond Yes, sofar never had a need to respond No.
Is there a eaglerc.usr setting to force (or make as default behaviour)
the opening of Brd & Sch files together. If not, could it be
implemented. Much requested for!!!
Kim
    autodeskguest over 15 years ago
    I agree with the suggestion that eagle tree should be able to open files
    of other applications. but this does not mean that EAGLE itself must
    have pdf viewer at all. just needs to pass the open command to the OS
    and let it launch the user's choice of viewer. That's all we are asking
    for.
    As far as the opening of single board/schema, I think it is a dangerous
    pitfall for the new user. As Joern points out, no need for yet another
    option, you don't want both windows, just close one.
    maybe when directed to open a .sch or .brd from the OS, EAGLE should
    check the folder for a project file and just open, or ask to open, the
    project. otherwise just view the file.
    "T G" <fightspammers@gmail.com> wrote in message
    news:hm6fit$2u0$1@cheetah.cadsoft.de...
    No, it doesn't, but so what? How often do you use that swiss army knife?
    It does a lot, but none of it well, don't you usually break out the real
    tools? Do you really want Eagle to be that way? It will be if the
    developers spend lots of time on non-Electronic stuff.
    I just want that all files (except backup files) in a project to be visible
    in Eagle, and when I double-click one of them, to be opened with associate
    program.
    This is the right way .
    The wrong way is to:
    -use Windows explorer to browse to my project,
    -click on eagle.epf (generic name, the same for all projects), by default
    unassocied with Eagle, so I must choose "Open with..." and browse for
    eagle.exe
    -wait for Eagle to load all libraries of that project (by default ALL
    libraries), and if after loading, I want to add an other component, I must
    wait again for ALL libraries to be loaded (try if you don't believe me)
    -only then view/edit the schematic/board
    Count this one too:
    -right click on a component, write down on a paper it's library and package
    - from Eagle CP: File/open/library + browse for that library (if it's not in
    the first "Library director" it's even worse), and then edit that component,
    according to a datasheet:
    -use again Windows Explorer to open that datasheet, related to your project,
    and stored on the same root folder with your project
    How many windows do you have opened by now: 1.Eagle CP, 2. Schematic,
    3.Board, 4.Lib editor, 5PDF viewer, 6Windows explorer?
    Eagle with tabs + PDF reader should be enaugh.... if Eagle would have tabs,
    and it would know how to open other files.
    And developpers won't spend lots of time on non-Electronic stuff, because it
    means just to pass to the OS commnad to open the file
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:hm3ksq$2oo$1@cheetah.cadsoft.de...
    Opening a project would be done by opening the .epf by any means (for
    example, double click in any file explorer or shell) - just as it is
    with any other IDE.
    This affirmation is valid only if 1 file does not contain all the
    information nedeed.
    But .sch file, or .brd or .lbr file contain all it needs to display
    schematic, board or library.
    "Joern Paschedag" <jpaschedag@t-online.de> wrote in message
    news:hm5ean$uk9$1@cheetah.cadsoft.de...
    Your "eficiency" is rubbish. If in windows explorer you click on an excel
    file for example, the explorer calls excel.exe which in turn opens the
    excel file. Same goes with eagle. So you should be a little more precise.
    It takes 5ms for explorer to call excel to open the excel files,
    it takes me 30 seconds to search for excel shortcut and then browse for the
    file I want to open
    So, yes, what I say it's eficiency
  • k.portman
    for.
    Agree. Enough to open an external Pdf viewer (Adobe, Foxit...). This
    would greatly help in navigating documentation (datasheets, project docs
    etc.). Currently though the Pdf files are not shown in the Eagle CP.
    Maybe an option in eaglerc to specify what files to show and howto open
    the viewer.
    Interface.FileViewer = ".pdf:AcroRd32.exe %1;.txt:Notepad.exe %1"
    You are saying to make Eagle open both sch/brd as defasult, no questions
    asked? This is the way I would like Eagle to behave. Then close the file
    you don't want/need (remember the dangers). In extreme cases where you
    really don't want the other file opened just rename the sch/brd pair to
    different names and only one file will be opened.
    There seem to be two groups of users: The "one task one tool" group
    and those who want to have a "do it all" Eagle.
    I don't want to use one more file manager with different user
    interface. It will never match the maturity of a "real" file manager.
    I would prefer a better integration of Eagle to be used with the OS
    means.
    My programming editor ("IDE"), HTML editor, office software etc. all
    do not have file manager functionality and I doubt anyone asks for
    such a feature.
    IMO the real benefit of the Eagle control panel is the library
    handling (browse, copy elements between libraries)!
    for.
    You open a can of worms. Eagle had to handle all the file
    associations, shell extensions etc. to do it well. That's not the task
    of a development software.
    Since the epf is in the same folder, the user could open the epf file
    instead of the brd or sch.
    And keep in mind that opening the epf file also means changing it if
    the epf file is set to "auto save".
    Oliver
    "Oliver Betz" <obetz@despammed.com> wrote in message
    news:m33fo5p7t7alqqss61uf04fa615g1ec25c@news.cadsoft.de...
    means.
    We don't want Eagle to know how to open porn!
    We create a electronics project. Eagle should have support for files related
    to electronics; nothing less, nothing more.
    such a feature.
    not quite... office is used to create office documents. It incorporates
    image viewer, equation editor (eved external eq. editor), and many many
    moote "tools"; Html editor - the same story.
    for.
    nop...
    If (file !sch and !brd and !lbr and !scr and !ulp), "shell run
    filename.ext".
    simple enough?!
    and the same novice user will copy only "eagle.epf" file to USB stick, to
    give to a friend the "schematic, board and all it needs"
    Why? because this is the file he uses to open the project.
    Who defines which file types are "related to electronics"?
    I prefer another definition: Eagle should have support for files related
    to /EAGLE/. See the difference?
    What would your stupid novice user do when he tries to give his friend
    the files of his latest software development? Copy only the project file
    of the IDE, without all the sources etc.?
    If that novice is /that/ stupid, he will need to copy the correct files
    in a second try - and hopefully learn from that. You can't protect
    novices from every stupidity.
    However, this detail discussion is somewhat meaningless here - there are
    more relevant, basic issues that should be addressed first (see the new
    thread in the suggest group).
    Tilmann
    news:hm891h$rtl$1@cheetah.cadsoft.de...
    I prefere an other way: "I want to make a board, for a schematic. I need 5
    datasheet, informations from the boardhouse, and some pictures. I want to be
    able to access all this from only one IDE, the one used for creating
    boards".
    I don't want to open (by hand, one after an other) half of the programs
    installed on my HDD to complete this simple project.; I don't want to swim
    in backup files to find my 3 usefull files.
    boards".
    Perhaps you got used to this method because you don't have a
    useful/powerful file manager? (This is not meant offensive - but I just
    can't imagine doing it that way could be considered as effective.)
    We have hundreds of projects organised in a hierarchical tree. Not all
    projects contain EAGLE data, and some contain several revisions of EAGLE
    files. Of course we have everything that is really related to the
    project in that particular project folder - however datasheets or
    boardhouse information definitely belongs at other places, since these
    are not project related (at least we use the same parts and boardhouses
    for more than one project...).
    You think of EAGLE as a shell, from where you want to process/manage the
    whole workflow. I think this is not what EAGLE was developed for. You
    should think about using a shell that is meant for exactly this task.
    Then you can do everything you mentioned above from that single program.
    You activate the /documents/ (not the programs!) and the OS calls the
    needed programs to open them, regardless of document type (EAGLE, PDF,
    Word, Picture or whatever else). Of course all project related
    documents/files are arranged in the same folder (or related subfolders),
    so you have them all at hand when you open that folder.
    Please take the time to really think about this. I'm pretty sure your
    workflow would be much more efficient (and the needed programs much less
    bloated) if your concept was more "object oriented" and less "program
    oriented" - perhaps after a short time of getting used to it.
    Tilmann
