    • Avnet Boards Community
EAGLE User Support (English) Open Sch & Brd files together
  • Replies 72 replies
  • Subscribers 180 subscribers
  • Views 7178 views
k.portman
k.portman over 15 years ago
Is there a way to open an existing Sch & Brd file together, by default.
When I double click either Sch or Brd file name on the Eagle Control
Panel it asks "Do you also want to load xxx.brd?" (or xxx.sch). I always
respond Yes, sofar never had a need to respond No.
Is there a eaglerc.usr setting to force (or make as default behaviour)
the opening of Brd & Sch files together. If not, could it be
implemented. Much requested for!!!
Kim
    autodeskguest over 15 years ago
    Am 24.02.2010 21:25, schrieb Olin Lathrop:
    Alexander Horst wrote on Wed, 24 February 2010 14:58
    A reason might be another user, who just wants to be asked again. So
    adding it as an option would solve the problem for any working style.
    But that's no reason at all without a reason why a user might want to be
    asked again. If you always want to open them together, then there is never
    any need to ask and nobody would want or need to be asked again. Can't you
    see what you're saying is circular reasoning?
    Sure it is. But isn't the purpose of options to allow a more heterogenous
    user base to be happy with the software?
    Usually I want them to be opened together. Tomorrow I may want to do it
    differently for whatever reason. So why not make it switchable?
    Alexander Horst wrote on Wed, 24 February 2010 15:38
    it
    OK, what reason?
    Because it's just silly superstition unless you can come up with a valid
    reason to ever open one file without the other.
    I can think of alot of things that would never make sense for Eagle to do,
    and I don't want a switch to disable each one.
    Oliver Betz schrieb:
    The real old-fashioned user doesn't use the Eagle control panel to
    navigate to a project.
    The centralized organization introduces several years ago is not
    appropriate in many cases.
    Ack.
    For us, this means we must put the files into the EAGLE project
    directory for working on them, and don't forget to move them back into
    our project hierarchy afterwards.
    This also applies to many settings in the eaglerc file, e.g. the
    Directories.* entries - one might want to have different path settings
    for different projects. IMO these directories are no "user" settings
    but "project" settings. Well - many users will use the same
    directories for all projects, so it's convenient for them.
    ...but if there was a way to have them different between projects, it
    would satisfy both kinds of users.
    This could simply be solved by having the "user" settings as
    defaults which can be overridden by "project" settings.
    Tilmann
    Alexander Horst schrieb:
    Often, there is no epf, e.g. when opening a sch&brd pair, which was sent
    by email. In this case I very often run into the behavior as described by
    Silviu.
    This could be solved if EAGLE would load some kind of default "project"
    settings when a sch/brd file is opened directly (instead of a project).
    Tilmann
    Silviu Epure schrieb:
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:hm3akc$b1l$1@cheetah.cadsoft.de...
    Well this is no problem at all, if you don't use the Windows Explorer
    for opening EAGLE files. Why don't you start EAGLE and load the files
    with File/Open? Or am I to old-fashioned here?
    Because Cadsoft's choise is to NOT USE Control Panel as FILE EXPLORER, but
    as "project explorer".
    I say-it for n'th times: Eagle Control Panel is an "feature" with low-to
    none use, as it is now.
    If there was a directory tree, or if Control Panel would display and permit
    opening other files too, maybe. But for now it's not usable this way.
    I want to open a file, not to open Eagle to open a file. It's a matter of
    eficiency....
    Your "eficiency" is rubbish. If in windows explorer you click on an
    excel file for example, the explorer calls excel.exe which in turn opens
    the excel file. Same goes with eagle. So you should be a little more
    precise.
    And, by the way, your tenor goes on my nerves.
    Gruß / regards
    Joern
    it
    OK, what reason?
    Assuming that both files exist and open I don't need a swich for the
    reason that it is the same amount of "work" to click on the switch or
    just to close one file.
    And for this sos (single open switch) image  you need a selector whether
    to open the board or the sheet and a switch to select whether the
    control panel should be opened... image
    Gruß / regards
    Joern
  • k.portman
    Il 24/02/2010 18.09, Olin Lathrop ha scritto:
    KP wrote on Wed, 24 February 2010 11:54
    Obviously you would also need a way to somehow revert your selection.
    You do? Can you explain a reason why you'd ever not want both the
    schematic and board open together, once they both exist?
    I can imagine only 2 situations when I might want to open only one of
    the respective sch or brd files.
    1) When I run into some inconsistencies between sch and brd. Then I
    would modify the odd file to match the counterpart file. Change the
    design (add, delete, rename...) and run Erc until you have fixed the
    errors, save both files and you are ok for the future. Suppose all this
    can be done having both sch and brd files open, so this might not be a
    valid case.
    2) When doing some very special modifications. Comes into my mind PCB RF
    Antennas. Maybe I want to replace the Antenna on my design. I might copy
    it from another brd file and paste to my new design, maybe replacing
    what I already have. Rename traces and symbols approprietly and run Erc
    to keep sch happy. To do all this I might want to work on brd file alone.
    I'd prefer much more that Eagle opened both sch & brd together as
    default (if both exist). I'd then just close the one I don't need to
    make these low level "hacks" (which I don't promote here).
    How Eagle behaves now I can have open sch from one design and brd from
    another design (ex. front.sch and back.brd together). Modifying either
    of these 2 files would create future Erc errors...
    Kim
    But wouldn't it be inefficient for Cadsoft to implement the zillionth
    file manager and for the user to learn it?
    eficiency....
    No, that's not so simple with Eagle since an Eagle project consists of
    many files compared to one Excel file.
    And you can hold many Excel files in one directory, but only ne Eagle
    project due to the magic name "eagle.epf".
    Oliver
    Ack.
    For us, this means we must put the files into the EAGLE project*
    directory for working on them, and don't forget to move them back into*
    as you know, I never move anything "into the EAGLE project directory"
    simply because there is no dedicated Eagle directory in my setup.
    Using my favourite file manager, I navigate to the directory where the
    brd/sch/epf/lbr... are located and start Eagle from there - usually by
    passing the name of the epf to Eagle (Windows: epf linked to Eagle
    with %1 in the command or "sendto" folder). The Eagle "project"
    directory (Directories.Epf from eaglerc) is simply the current
    directory ".", and other directory settings also contain ".".
    IMO this method is much more efficient than the Cadsoft suggestion if
    you have a large file tree containing also other files than Eagle
    projects.
    A drawback is the uncertain "current directory" when using the sendto
    menu, and "." might be not obvious for some user.
    I refresh the claim for better handling of arbitrary located projects
    in a new thread in eagle.suggest.eng.
    Ack.
    But how should we control to which file new or changed settings are
    stored?
    We should discuss this not in this thread but in a suggest group.
    Oliver
    "Joern Paschedag" <jpaschedag@t-online.de> wrote in message
    news:hm5ean$uk9$1@cheetah.cadsoft.de...
    Your "eficiency" is rubbish. If in windows explorer you click on an excel
    file for example, the explorer calls excel.exe which in turn opens the
    excel file. Same goes with eagle. So you should be a little more precise.
    Hey, I've just give you a good example where a common stupid user like me
    (who uses computer 10h/day, 30days/month, for about 10 years now, most of
    the time for electronics) find behaviour of the Eagle "strange".
    I think this way: "I want to open the schematic with ultrasonic emitter"...
    and I do the simplest way to open that schematic...
    I don't think that "I should find the .epf file for the project that I've
    once created to make a ultrasonic emitter"
    And to be usefull. Eagle Control Panel should at least support pdf and
    images....Could be displayed/preview on the "white (now - 90%of time) area
    of the Control Panel"
