    • Avnet Boards Community
EAGLE User Support (English) Open Sch & Brd files together
  • Replies 72 replies
  • Subscribers 180 subscribers
  • Views 7208 views
k.portman
k.portman over 15 years ago
Is there a way to open an existing Sch & Brd file together, by default.
When I double click either Sch or Brd file name on the Eagle Control
Panel it asks "Do you also want to load xxx.brd?" (or xxx.sch). I always
respond Yes, sofar never had a need to respond No.
Is there a eaglerc.usr setting to force (or make as default behaviour)
the opening of Brd & Sch files together. If not, could it be
implemented. Much requested for!!!
Kim
    autodeskguest over 15 years ago
    "Silviu Epure" wrote:
    I prefer another definition: Eagle should have support for files related
    to /EAGLE/. See the difference?
    I prefere an other way: "I want to make a board, for a schematic. I need 5
    datasheet, informations from the boardhouse, and some pictures. I want to be
    able to access all this from only one IDE, the one used for creating
    boards".
    that's your - very specific - usage scenario. But your PDF-centric
    view of things doesn't match everyone's needs.
    I'm creating documentation while I'm working with Eagle. That's
    project specific documentation I want to store in vicinity of the
    Eagle files.
    But usually I do not want to store the documentation of the parts
    used in the same directory since I re-use the parts in other projects.
    Therefore this kind of documentation resides in a completely different
    tree. I can put links to them  in the project directory.
    That's my - also specific - workflow.
    I don't want to open (by hand, one after an other) half of the programs
    installed on my HDD to complete this simple project.; I don't want to swim
    in backup files to find my 3 usefull files.
    If you would learn to use a decent file manager (e.g. some "Commander"
    like Freecommander, Total C. etc.), you could filter the Eagle backup
    files from your view.
    Then you might realize that the "one tool for one task" is usually the
    best approach.
    A good file manager has preview for many file types, opens
    everything with the right (or individually selected) applications,
    jumps to your preferred paths quickly and much more.
    My approach ist not to make Eagle a better file manager but to improve
    Eagle's capabilities of integration to use it with a filemanager (also
    "Windows Explorer" is nor the worst file manager).
    The strength of the Eagle Control Panel is library browsing and
    management.
    Oliver
    Silviu Epure wrote on Fri, 26 February 2010 06:13
    need 5
    to be
    boards".
    The point is that's unreasonable to ask Eagle to do.  You already have good
    tools to do all those things.  Let's not ask Eagle to be another OS.
    Besides, what are datasheets doing in a board directory anyway?  Datasheets
    apply accross all projects.  I keep a completely independent tree of
    datasheets elsewhere.  I don't want separate copies of the MMTB4401
    datasheet in every Eagle board directory I used one of those transistors
    on, for example.
    swim in backup files to find my 3 usefull files.
    In Windows you don't need to open the programs for viewing particular files
    first.  Just enter the file name in the command shell window and Windows
    will open the associated program with that file automatically.
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:hm8hvh$3gg$1@cheetah.cadsoft.de...
    5
    be
    boards".
    Perhaps you got used to this method because you don't have a
    useful/powerful file manager? (This is not meant offensive - but I just
    can't imagine doing it that way could be considered as effective.)
    We have hundreds of projects organised in a hierarchical tree. Not all
    projects contain EAGLE data, and some contain several revisions of EAGLE
    files. Of course we have everything that is really related to the
    project in that particular project folder - however datasheets or
    boardhouse information definitely belongs at other places, since these
    are not project related (at least we use the same parts and boardhouses
    for more than one project...).
    swim
    You think of EAGLE as a shell, from where you want to process/manage the
    whole workflow. I think this is not what EAGLE was developed for. You
    should think about using a shell that is meant for exactly this task.
    Then you can do everything you mentioned above from that single program.
    You activate the /documents/ (not the programs!) and the OS calls the
    needed programs to open them, regardless of document type (EAGLE, PDF,
    Word, Picture or whatever else). Of course all project related
    documents/files are arranged in the same folder (or related subfolders),
    so you have them all at hand when you open that folder.
    Please take the time to really think about this. I'm pretty sure your
    workflow would be much more efficient (and the needed programs much less
    bloated) if your concept was more "object oriented" and less "program
    oriented" - perhaps after a short time of getting used to it.
    Tilmann
    1. I do have a usefull file manager (totalcmd), and I know how to use-it.
    But a full folder is a full foder no matter what file browser you use.
    2. My concept is not "program oriented", but "project oriented"
    3. and be honest... would you be bothered if Eagle could open pdf with
    external application?
    It is allready support writing pdf's....
    I see discution has become personally...
    "KimP" <kim.portman@selectrasrl.it> wrote in message
    news:hm33ok$8nr$1@cheetah.cadsoft.de...
    When I double click either Sch or Brd file name on the Eagle Control Panel
    it asks "Do you also want to load xxx.brd?" (or xxx.sch). I always respond
    Is there a eaglerc.usr setting to force (or make as default behaviour) the
    opening of Brd & Sch files together. If not, could it be implemented. Much
    requested for!!!
    Kim
    Yes, sch and brd should always open together, no matter if user clicked on
    sch, brd or epf file. Without confirmation, because it's not needed.
    No - that's why I explicitly mentioned that my post was not meant offensive.
    I was just trying to understand why you have this strong interest in
    using EAGLE as your file manager.
    Tilmann
    KP wrote on Wed, 24 February 2010 06:49
    always
    So I've followed this entire thread and I'll add my $0.02CDN finally.
    I understand the notion that EAGLE is a CAD tool and we'd rather have the
    limited developer time spent on improving the CAD part of the tool.  We're
    not a group about bells and whistles but real, bottom-line functionality.
    I agree with that.
    However, I think many under-estimate the role that good documentation plays
    in CAD design.  In fact, I would argue that it that is just as important as
    the actual schematic.  If you don't have the right input data (specs,
    datasheets, requirements, ...) then you won't have the right output from
    the CAD tool.  So I don't think it's unreasonable to request better
    handling of that data.
    The problem is that the format that data takes can be widely varying.
    Building in a viewer for every possible type of file would be a huge
    undertaking and probably a lot of wasted effort.
    Can't we leverage the OS in this case though?  EAGLE 5 already has the
    facility to use an external text editor.  Why not expand that a bit to
    allow the user to maintain a list of known extensions and the external
    commands to run when that type of document is activated from Control Panel.
    It wouldn't take that much extra effort since the infrastructure appears
    to be there already.  The list could come pre-populated with obvious
    settings but the user could change them as required.
    Doesn't that fit everyone's need?  A clean approach that gives easy access
    to the design documents from within Control Panel.  Not much effort to
    distract from other features and EAGLE doesn't become bloated.  A win-win I
    think.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    think.
    Unfortunately, getting this to work is some effort, since you would have
    to set up that file association list first before you can make use of
    it. That's not a works-from-the-box approach, IMHO.
    Luckily, the OS already has exactly such a list - why not simply use
    that? You can pass the name of a file to the system shell and have the
    related application started automagically.
    Tilmann
    Am 26.02.2010 18:43, schrieb Tilmann Reh:
    think.
    With James' approach it would be possible to configure which files Eagle's
    Control Panel shows. I'd rather not have all the files shown in the
    folder list, as was mentioned by someone else in this thread already.
    autodeskguest over 15 years ago in reply to autodeskguest
    Please read this carefully:
    In order to implement double clicking and opening of files from the
    control panel of EAGLE. does not require to EAGLE to do anything, have
    any file associations, nor any file viewers. as all have stated, this
    already resides in the OS. all that is required is to pass "START
    path\filename.ext" to the OS. just one string. that's it. maybe 10 lines
    of code. no viewers, no tables, no nothing. and stop hiding files in the
    control pane - which is simplifying the code. if this is untrue, I
    challenge you to provide evidence to the contrary.
    nobody is asking for EAGLE to be aware of or do anything with any type
    of file except it's own. if you think i or anyone else here asked for
    that, you are projecting your own prejudices, misunderstanding and
    perhaps your ignorance of programming into the debate. please quote for
    me where I, or anyone else, has asked for EAGLE to be aware of and
    handle different file types. right, we only asked that they be opened in
    the native application, not EAGLE, you misunderstood us. when we say
    open, we mean "from the control panel", not "by the EAGLE application".
    personally, i don't like the control panel. i totally agree that EAGLE
    should be as light and CAD oriented as possible - I'd even dump the
    integral text editor. i think CADSOFT should concentrate on real
    features that improve the tool, not libraries, not databases. i think
    there is real room to rethink EAGLE's project management paradigm - I
    myself found it strange when introduced to it.
    but, since I must use the control panel, I wish it wouldn't get in my
    way of organizing projects in the way that works best for me. not for 10
    lines of code at any rate.
