    • Avnet Boards Community
EAGLE User Support (English) Open Sch & Brd files together
  • Replies 72 replies
  • Subscribers 180 subscribers
  • Views 7220 views
k.portman
k.portman over 15 years ago
Is there a way to open an existing Sch & Brd file together, by default.
When I double click either Sch or Brd file name on the Eagle Control
Panel it asks "Do you also want to load xxx.brd?" (or xxx.sch). I always
respond Yes, sofar never had a need to respond No.
Is there a eaglerc.usr setting to force (or make as default behaviour)
the opening of Brd & Sch files together. If not, could it be
implemented. Much requested for!!!
Kim
    autodeskguest over 15 years ago in reply to autodeskguest
    3. and be honest... would you be bothered if Eagle could open pdf with
    external application?
    It is allready support writing pdf's....
    Absolutely I Would Be Bothered if Eagle could open pdf files, partly
    because you then want more.
    But mostly, this bothers me because my project tree as viewed from Eagle
    gets as cluttered as when viewed from XYplorer. I can see tons of files,
    related to the project but NOT part of Eagle and then have lots more
    hunting and scrolling when switching between schematics in multiple
    projects. It would really annoy me.
    That said, If we had a setting in the CP to create custom filters so we
    only see the file types we want to see, it's not a problem for me
    anymore and I say go ahead, just so everyone stops complaining.
    By the time Klaus has read this entire thread, he could have implemented
    the suggestion with a filter setting. Talk about wasting developer's
    time...  image
    Travis
    I just want that all files (except backup files) in a project to be visible
    in Eagle, and when I double-click one of them, to be opened with associate
    program.
    This is the right way .
    The wrong way is to:
    -use Windows explorer to browse to my project,
    -click on eagle.epf (generic name, the same for all projects), by default
    unassocied with Eagle, so I must choose "Open with..." and browse for
    eagle.exe
    -wait for Eagle to load all libraries of that project (by default ALL
    libraries), and if after loading, I want to add an other component, I must
    wait again for ALL libraries to be loaded (try if you don't believe me)
    -only then view/edit the schematic/board
    Count this one too:
    -right click on a component, write down on a paper it's library and package
    - from Eagle CP: File/open/library + browse for that library (if it's not in
    the first "Library director" it's even worse), and then edit that component,
    according to a datasheet:
    -use again Windows Explorer to open that datasheet, related to your project,
    and stored on the same root folder with your project
    How many windows do you have opened by now: 1.Eagle CP, 2. Schematic,
    3.Board, 4.Lib editor, 5PDF viewer, 6Windows explorer?
    Eagle with tabs + PDF reader should be enaugh.... if Eagle would have tabs,
    and it would know how to open other files.
    And developpers won't spend lots of time on non-Electronic stuff, because it
    means just to pass to the OS commnad to open the file
    Have you not learned how to associate files in windows? If you have,
    your 1st complaint is invalid, though it would be nice if Eagle
    associated the epf files.
    So what, you have 6 windows open? Complaining about that is fairly
    laughable when you see what I keep open when into a project:
    Firefox with 70 to 90 browser tabs open
    Eagle with 4 to 5 windows
    Thunderbird for email with 3 or 4 tabs open (each tab is an email)
    MPLAB with 5 or 6 tabs open (each tab is a file)
    PICKit PIC Programmer
    XYplorer
    Foxit reader with about 7 to 10 documents open
    SoftScope (PC oscilloscope software)
    OpenOffice Writer and/or Draw and/or Calc
    GIMP
    Sometimes also AutoCAD
    Notepad or PSPad
    Serial port diagnostics software I wrote to troubleshoot several of my
    projects
    MS Visual Studio with 5 to 20 tabs open.
    I regularly run all of that simultaneously without noticeably slowing
    down my laptop, and even more on my desktop. Up until about 2 years ago
    I did that all on a 1GHz PC, and that could get slow at times... Why
    complain about 6 windows?
    Just today I had all that running except for OpenOffice, GIMP, AutoCAD,
    or Visual Studio while on-site troubleshooting...
    That said, I agree Eagle should have tabs, suggested it months ago.
    I highly disagree it should include a pdf viewer built in.
    Travis
    and stop hiding files in the
    control pane - which is simplifying the code. if this is untrue, I
    I will be very unhappy if no file filtering is available. The best
    arrangement is to provide a customizable filter, which is not hard at all.
    perhaps your ignorance of programming into the debate. please quote for
    me where I, or anyone else, has asked for EAGLE to be aware of and
    handle different file types. right, we only asked that they be opened in
    the native application, not EAGLE, you misunderstood us. when we say
    open, we mean "from the control panel", not "by the EAGLE application".
    Actually one person did request a pdf viewer to be built-into Eagle...
    or did they say that since EAGLE can generate a pdf file, it might as
    well be able to display one? well, that might be taken either way,
    especially if you did not get the whole context.
    "T G" <fightspammers@gmail.com> wrote in message
    news:hm9qs0$vc5$1@cheetah.cadsoft.de...
    Why complain about 6 windows?
    Because it could be better! It's not this the scope of the forum, where
    developpers find user's needs ?
    I know, this is an other discution, on other thread
    agree with you. It was a bad idea to create a built-in pdf viewer, by
    electronics developper. There are many goods applications for this purpose.
    news:hm9rgo$1rq$1@cheetah.cadsoft.de...
    I admit, I'm that person, but it was just an idea (to display content of pdf
    in the "information" area of the Control Panel)
    But implies hard work from developpers, for ... almost nothing.
    So I also admit it's not a good idea.
    "Silviu Epure" wrote:
    1. I do have a usefull file manager (totalcmd), and I know how to use-it.
    Then you can set a view filter in Total Commander to see only the file
    types you want to see. That's what you asked for, isn't it?
    But a full folder is a full foder no matter what file browser you use.
    That's not the question, you suggested the Eagle Control Panel to show
    a certain set of files, and that's what a good file manager already
    does.
    2. My concept is not "program oriented", but "project oriented"
    Where is the difference?
    Yes.
    So Eagle should also contain/support a Gerber Viewer, picture viewer
    etc?
    Oliver
    "Oliver Betz" <obetz@despammed.com> wrote in message
    news:02sko598h1681quh34cqi7u0sakcq0e174@news.cadsoft.de...
    From a file manager I want to see all files. This for is a "file manager".
    Or do you like to see only what make you happy (3 files shown, and 10k files
    hidden, and then wander "where is the free space of the HDD?!")
    does.
    1. If you were not aware of this, Eagle Control Panel DOES show some pdf
    files in tree. (It has a filter, but it's not so good in hiding pdf
    files...)
    2. what it's your opinion about files with arbitrary extension, files that
    can be created with ulp's in project folder, and are perfectly visible from
    CP?!!!
    Realy do you consider there is no difference?
    Yes.
    Why? because it will know how to properly open a file that now it's
    displayed in CP, and it's opened with integrated text editor?!
    etc?
    A custom filter shoud satisfy everybody. Default operation should be: sch,
    brd, lbr, scr, ulp displayed, other files not. User (like me) could add
    extensions in eaglerc.usr files, so this files could be passed to OS to be
    opened.
    Please, comment the attached image.....
    So what do you think the configurable and switchable view filters in
    the file manager are intended for?
    IMO Eagle should not display it.
    That's also my comment you requested in your other posting.
    Oliver
