EAGLE User Support (English) Doubling up tracks on different layers
  • Replies 10 replies
  • Subscribers 178 subscribers
  • Views 1880 views
autodeskguest over 15 years ago
Guys,
I've got a problem I hope someone can help me out with.  I have some
very high current traces on my PCB (15A and 30A).  I'm using 2oz copper
but in order to get track widths that aren't completely ridiculous I
need to double up the tracks on two layers.  I'm new at Eagle (last used
OrCAD PCB editor which is a stripped down version of Allegro) and I
can't seem to make this happen.  When I route the initial track on the
first layer naturally the ratsnest for this route disappears (since it
is now connected).  Eagle won't allow me to start a track on the second
layer because there is no longer an active ratsnest.  How do I get
around this?
This is also a generic issue.  If I want to start routing on a pin that
the ratsnest currently isn't touching (but it is unrouted, the ratsnest
is just terminated on a different unrouted pin) Eagle won't let me.
This is different from Allegro where I could start routing on any pin
and if it was unrouted the ratsnest would immediately snap to that pin.
  This is somewhat annoying since it is forcing me to route nets in the
order that Eagle decides to snap the ratsnest to instead of routing in
the order that is most logical to me.  I'm sure there is a way around
this, but I've yet to find it.
Michael
    If you hold CTRL while selecting where to start routing then you can start
    at any point.
    "Michael Sansom" <mssansom@hotmail.com> wrote in message
    news:hp2ds9$rm0$1@cheetah.cadsoft.de...
    Guys,
    I've got a problem I hope someone can help me out with.  I have some very
    high current traces on my PCB (15A and 30A).  I'm using 2oz copper but in
    order to get track widths that aren't completely ridiculous I need to
    double up the tracks on two layers.  I'm new at Eagle (last used OrCAD PCB
    editor which is a stripped down version of Allegro) and I can't seem to
    make this happen.  When I route the initial track on the first layer
    naturally the ratsnest for this route disappears (since it is now
    connected).  Eagle won't allow me to start a track on the second layer
    because there is no longer an active ratsnest.  How do I get around this?
    the ratsnest currently isn't touching (but it is unrouted, the ratsnest is
    just terminated on a different unrouted pin) Eagle won't let me. This is
    different from Allegro where I could start routing on any pin and if it
    was unrouted the ratsnest would immediately snap to that pin. This is
    somewhat annoying since it is forcing me to route nets in the order that
    Eagle decides to snap the ratsnest to instead of routing in the order that
    is most logical to me.  I'm sure there is a way around this, but I've yet
    to find it.
    Michael
    Former Member over 15 years ago
    Michael Sansom wrote on Thu, 01 April 2010 09:24
    Guys,
    used
    around this?
    Michael
    I can't help on the first issue, but for the second one, press and hold
    ctrl when you are starting your trace and you can start at any location on
    the net.
    Also, remember, too, you can press down alt as well to use the alternate
    grid spacing temporarily.
    DAvid
    Guys,
    used OrCAD PCB editor which is a stripped down version of Allegro) and
    I can't seem to make this happen.  When I route the initial track on the
    around this?
    Michael
    the net.
    DAvid
    Thanks to both of you.  Yes, I use the ALT key a lot to switch to my
    minimum grid spacing and that works well but I wasn't aware of the CTL
    key allowing me to start a line on a pin/pad that wasn't terminated in a
    ratsnest line.
    That first question is really important.  The ability to run the same
    track on different layers is a key ability when doing layouts with high
    current nets.  Doug seems to imply that using CTL might work in that
    situation as well.  I'll try it and see what happens.
    Moving from one layout package to another is always a pain as you get
    trained to think in terms of whatever package you have the most
    experience with.  After using Eagle for a week or so it seems that there
    are many fine attributes of this package.  The ability to alter a
    schematic and have the results show up immediately in the pcb layout
    package is a huge plus.  And in terms of pure execution speed it seems
    faster than Allegro in many places.  However, there are a few things
    that I really miss.  Allegro would let me constrain my tracks to be
    purely orthogonal with 45 degree bends, and would automatically keep
    tracks vertical/horizontal as you routed across the board.  Also, it
    would enforce spacing requirements in real time as you routed a trace
    (so you didn't find out that you have tracks closer than your design
    rules permit only after running a DRC).
    All and all it is a very good value.  However, I would think that with
    the addition of a few key features it could compete with anything out
    there.  Would be interesting to know what sort of features are on the
    road map for future releases.
    -Michael
    Indeed Doug was correct, you can double up a track by starting it by
    holding the CTRL key down.  However, you have to remember to release
    the CTRL key before making the next connection (otherwise it will just
    literally "throw a curve" into your track).  Very useful information.
    Thanks guys.
    Guys,
    and I can't seem to make this happen. When I route the initial track
    on the
    around this?
    Michael
    location on
    the net.
    DAvid
    ratsnest line.
    faster than Allegro in many places. However, there are a few things that
    I really miss. Allegro would let me constrain my tracks to be purely
    orthogonal with 45 degree bends, and would automatically keep tracks
    vertical/horizontal as you routed across the board. Also, it would
    enforce spacing requirements in real time as you routed a trace (so you
    didn't find out that you have tracks closer than your design rules
    -Michael
    You don't need to route on the second layer, just draw the copper with
    WIRE or POLYGON and name it to the net it should belong to.
    Another option which is a little dangerous would be to move the routed
    track to a new layer and include that layer in both the top and bottom
    Gerbers.
    "Gary Gofstein" <nospam@use.forum.net> wrote in message
    news:hp312q$b1u$1@cheetah.cadsoft.de...
    Gerbers.
    what about Cut/Paste/Change layer of the pasted tracks?!
    it worked for me some time ago
    autodeskguest over 15 years ago in reply to autodeskguest
    To change the orthogonal bend style when routing, you can use the right
    mouse button while you're drawing the trace.  Just keep cliking the right
    button to change the angle style to what you like.
    I don't know a way to enforce spacing from one wire to the next while
    routing, I've always controlled this with grid, track-width, and being very
    careful, but it's a pain.  PADs had a mode where it would "hold" the
    routing to design rule spacings as you were doing it, but I haven't found a
    way to do this in Eagle.
    If anyone knows, I'd be very interested too.
    Cheers,
    Alex
    news:hpg1g0$lrj$1@cheetah.cadsoft.de...
    I like Eagle and think it is a hell of a value for the money, but it is a
    little frustrating that there are a few features found in other tools that
    are missing that would take Eagle to the next level and allow it to
    compete with almost any package out there.  Hopefully some of this will
    get addressed in future releases.
    People are not the same. Software is made by people for people. So it can't
    be an application to please everyone. Eagle is made for people that love and
    use Eagle. Some of them want to bring new features in this software, some of
    them wants to keep-it as it is (even changing the version number is an
    "almost acceptable change" for some of them image )
    And the "not so good" news is that Cadsoft is never hurry to implement
    changes in their software (maybe the effort is too heavy, or they can't, or
    they won't image )
    But as it is now, it's usable for much more than just routing a PCB with 3
    resistors and an IC.
    Cheers,
    Alex
    Yeah, I discovered the routing mode that enforced orthogonal tracks with
    45 degree bends, and that does help.  However, if after routing a track
    in this manner I then move/shove the track I loose my guarantee of
    orthogonal lines and 45 degree bends, which is a bummer.
    I've seen PADS and it's enforcement of spacing rules in real time while
    routing is very much like Allegro's.  That feature tremendously speeds
    manual routing and is a huge asset.  I don't believe that Eagle can
    support this as it stands.  I don't know how PADS works in this respect
    but Allegro would also enforce spacing rules when you moved/shoved
    tracks after initial routing. i.e. if you shoved a track too close to
    the adjacent track such that it violates the spacing constraints it
    would either shove the adjacent track over (if it could without it
    colliding with something else) or it would just not allow it to happen
    and the track you were shoving would "bounce" off.  Again, great asset
    to have when routing a dense board.  Both tools allowed you to easily
    optimize your routing channel such that every track in parallel was
    placed at the minimum spacing.
    a little frustrating that there are a few features found in other tools
    that are missing that would take Eagle to the next level and allow it to
    -Michael
    Michael Sansom wrote on Tue, 06 April 2010 15:19
    to
    -Michael
    Yes, that's the feature of PADS that I miss from 10 yrs ago.  It would be a
    massive benefit to have this.
    One thing you might try is selecting the segments in a route by drawing a
    group around them, then moving the group as a whole in one direction.
    Maybe you already know this but Eagle lets you define a group by drawing an
    arbitrary surrounding shape around it... so it's possible to select
    arbitrary shaped collections of objects, not just rectangles.
    Cheers,
    Alex
