EAGLE User Support (English) Component Values on Schematic
  • Subscribers 180 subscribers
  • Views 1117 views
Ok, more newbie questions.
I know that Eagle's philosophy is to have generic valueless components
(for instance, a generic resistor) which the user then assigns a value
to (for instance "10k") when the component is placed on the schematic.
However, for my business I want to generate BOMs automatically which
will then get uploaded to an ERP/MRP system with hopefully minimal hand
editing.  To achieve this it is desirable for me to create separate part
numbers for each component that correspond to my own internal part
numbering system.  Therefore, each component will have one package and
one value.  Is there a way to "hardcode" the values on each part so that
I don't have to manually go and edit it after I drop the part?  Also, in
some cases, it would be advantageous for the part to have this
pre-assigned value, but not have that value displayed on the
schematic.  For example, on a connector I might not want the part number
displayed on the schematic, but I do want it to show up in the BOM when
I run bom.ulp.  So, is there a way to have an invisible value on a part?
-Michael
    Michael Sansom wrote on Fri, 09 April 2010 16:05
    Not exactly.  You can set up devices to be valueless, but also to have
    predefined values.  This is what value on/off in the device means, although
    I can never remember which way on or off is (what a stupid choice of names,
    like CUT really does COPY).
    Yes.
    Quote:
    Also, in
    schematic.
    So don't put >VALUE in the symbol definition anywhere.
    part?
    I think you should leave the value attribute for just that and use your own
    private attribute for your internal part number.  A connector is a good
    example where you want the value to show something else.  You might want to
    the value displayed on the silkscreen so the connector can be labeled IN,
    OUT, Power, or whatever.
    Thanks Olin, that was most helpful.  I agree with you on the value
    on/off being counterintuitive and difficult to remember (funny how those
    things seem to go together).  The use of the value on/off has been
    difficult to grasp and I'm still not sure exactly how and when to use
    it.  I suppose I'll have to resort to the manual.  Great tip about not
    putting ">VALUE" in the symbol keeping the value invisible on the schematic.
    Thanks again,
    -Michael
    On 4/9/2010 2:20 PM, Michael Sansom wrote:
    your own
    want to
    Thanks Olin, that was most helpful. I agree with you on the value on/off
    being counterintuitive and difficult to remember (funny how those things
    seem to go together). The use of the value on/off has been difficult to
    grasp and I'm still not sure exactly how and when to use it. I suppose
    I'll have to resort to the manual. Great tip about not putting ">VALUE"
    Thanks again,
    -Michael
    another quickie way to get a value off the schematic is to SMASH the
    part and then DELETE the value text. sometimes it comes back though...
    Gary Gofstein wrote on Fri, 09 April 2010 18:26
    I thought deleting a individual text string of a smashed part unsmashed
    that string.  Maybe that changed somewhere in some rev, but I'm pretty sure
    that's how it used to work.  That's why I create a layer called "trash" in
    the board, and move smashed text I don't want to that layer.
    autodeskguest over 16 years ago in reply to autodeskguest
    don't know - works in v4.16. if you delete both smashed texts, they will
    come back however. but I like the idea of just moving it to an invisible
    layer, thanks.
