EAGLE User Support (English) Making a pad with rectangular hole in a package when creating my own part.  How?
  • Subscribers 178 subscribers
  • Views 928 views
unebonnevie
unebonnevie over 15 years ago
I am creating a part (an SPDT switch) that an anchor pin which is 2mm wide.
When creating the package for this part, EagleCAD has pad but with circular
drill hole.  How would I make the rectangular hole, in this case, 2mmx0.5mm?
Thanks.
    autodeskguest over 15 years ago
    I think you should draw a rectangular on milling layer.
    of course, the pad is needed.
    I has been asked factory. generally, "if a hole on pad, they will make a
    through hole".
    so you should better tell the factory, where need special hole.
    AL wrote on Sat, 08 May 2010 05:07
    wide.
    circular
    2mmx0.5mm?
    Why bother?  Unless a 2mm hole would interfere with something else, just
    use that.
  • unebonnevie
    "Olin Lathrop" <eagle@embedinc.com> wrote in message
    news:hs3p0l$enl$1@cheetah.cadsoft.de...
    wide. When creating the package for this part, EagleCAD has pad but with
    circular drill hole.  How would I make the rectangular hole, in this
    case,
    2mmx0.5mm?
    use that.
    I am sorry...I don't understand.  Could you expand you answer with a bit
    more details?
    Thx.
    "AL" <unbonnevie@yahoo.com> wrote in message
    news:hs6mqh$58c$1@cheetah.cadsoft.de...
    case,
    2mmx0.5mm?
    use that.
    more details?
    Thx.
    what Olin intended to express: As long as you can live with 2mm holes
    instead of milling a 2 x .5 mm slot, you should do so. Drilling is much
    cheaper than ordering extra (and plated) milling at the pcb manufacturer.
    Use only milling if this is the only way to get the part onto the pcb. I
    would recommend that, too.
    Carsten
