EAGLE User Support (English) Is this group still active?
  • Replies 28 replies
  • Subscribers 193 subscribers
  • Views 3483 views
Oppie
Oppie over 10 years ago
I have not seen any new messages lately. Is my reader broken?
Do messages here mirror the element-14 discussions?
  • rachaelp
    rachaelp over 10 years ago in reply to ChristyZ
    Hi Christy,
    It seems the link back to the E14 forums is down again. Posts made on EAGLE Central aren't getting back here at the moment. I believe they are going the other way though (or they were yesterday).
    Best Regards,
    Rachael
  • ChristyZ
    ChristyZ over 10 years ago in reply to rachaelp
    Thanks Rachael.
    We had an issue with our primary server (which is the main node that handles the sync) earlier this week which I suspect caused the duplication. I wasn't aware it had stopped syncing since then. We will look into it immediately.
    Thanks for letting us know.
    Christy
  • rachaelp
    Hi Christy,
    Just in case you aren't aware, this issue seems to have cropped up again. It was double posting yesterday and then stopped working so I assumed you guy's probably deliberately took out the incoming sync (outgoing is still fine). Is there an ETA for this being fixed?
    Many thanks,
    Rachael
  • ChristyZ
    Hi everyone,
    Because we can't resolve the duplicate issue until our release on May 10th,
    we've temporarily shut off the syncing between element14 and the CadSoft
    forums until that fix is deployed.
    As soon as we have that fix deployed (as it requires a full build of our
    code-base) we will re-enable the sync and any messages that have been
    posted between the two sites should sync and the duplication issue will be
    resolved (has been resolved in our test environment).
    We apologize for the inconvenience but this should have it licked this
    time! Thanks for your patience.
    Christy - Development & Platform Director, element14
  • ChristyZ
    Hi everyone,
  • ChristyZ
    Hi everyone,
  • ChristyZ
    ChristyZ over 10 years ago in reply to Matt
    Because we can't resolve the duplicate issue until our release on May 10th, we've temporarily shut off the syncing between element14 and the CadSoft forums until that fix is deployed. I'm posting this here on element14 expecting that it will not sync to the forums (and I'll go post a message to the forums directly).
    As soon as we have that fix deployed (as it requires a full build of our code-base) we will re-enable the sync and any messages that have been posted between the two sites should sync and the duplication issue will be resolved (has been resolved in our test environment).
    We apologize for the inconvenience but this should have it licked this time! Thanks for your patience.
    Christy - development director, element14
  • Matt
    Matt over 10 years ago in reply to rachaelp
    Thanks for letting us know.. we've found the source of the duplicates issue and a fix is in progress. It'll need to get tested and deployed in an upcoming release.
    Matt.
  • rachaelp
    rachaelp over 10 years ago in reply to Dudley
    Hi Dudley,
    It seems there is still a problem with the link unfortunately. Any posts made over in Eagle Central appear multiple times over in this Element14 forum it seems.
    Best Regards,
    Rachael
  • Oppie
    Oppie over 10 years ago in reply to Dudley
    "Dudley Nelson" <dnelson@premierfarnell.com> wrote in message > We found
    that there was a problem with the linkage. The community
    website runs with four separate servers, and one of those four had a
    connectivity problem with the news group.
    Dudley
    Much appreciated Dudley
