EAGLE User Support (English) Eagle 7.6.0 Linux x64 Control Panel "Name" window resize issue
  • Replies 10 replies
  • Subscribers 190 subscribers
  • Views 1214 views
craigarno
craigarno over 10 years ago
I'm running OpenSUSE 12.3 x64 and having a problem with Eagle Control
panel in versions 7.5.0 and 7.6.0 (7.4.0 works fine).
When I try to resize the "Name" panel by hovering over the vertical bar
until it turns into a bidirectional arrow, then try dragging this, the
problem shows.  The Name Window collapses to an even smaller size and
cannot be moved. This effectively hides all the names, making the
control panel unusable under Linux.
I tried the Windows version of Eagle 7.5.0 and 7.6.0 and they don't
display this problem.
Craig
    autodeskguest over 10 years ago in reply to Joop14
    On 25/05/16 09:28, Teuniz wrote:
    I would like to ditch KDE but I need it to run Kate, my favorite text
    editor for programming.
    I still haven't found something that is as good as Kate.
    I guess this is just one of those sources of holy wars. My personal
    experience of Kate as a programming editor was enough to drive me back
    to ViM! I mostly use Nedit on Linux, although Scite is tolerable. I'm
    almost tempted to say I've not found a Linux programmer's editor to
    match Notepad++ on Windows!
    I haven't used KDE for a long time.
  • Joop14
    Joop14 over 10 years ago
    I'm a long term OpenSuse user, now using OpenSuse 13.2 & KDE.
    I agree with the complaints but prefer to stick with the devil I know.
    But now, guess what. After doing some updates/patches, Kate crashes when
    opening a file that
    contains only two characters: space and newline. Also, in Dolphin,
    right-click on that
    textfile and select properties. Dolphin crashes.
    And it seems that they are not going to patch it for OpenSuse 13.2 users.
    https://bugs.kde.org/show_bug.cgi?id=348977
  • Joop14
    opening a file that
    right-click on that
  • kikoun
    kikoun over 10 years ago in reply to craigarno
    Hi Craig
    I understand your point. At work, I think twice (or more) before asking for a soft, OS or computer update to the TI department because of the waste of time it can produce.
    Even at home, I don't change easily, that why I'm still running 13.2  and not the leap 42.1. I just tried it on a laptop I barely use so I could not risk to be stuck with bugs from an un-really tested version. I was right to test it on this old laptop: this Leap 42.1 that should be the Opensuse 'Stable' version wasn't very stable at all (Kwin crashes every 5 minutes, random dual screen configuration at each login etc...).
    On that point, you’re right, Opensuse really disappoints me : they didn't focus on the stability, but only on the 'shiny-brand-new-but-buggy-feature-that-I-don't-even-care'. They should reserved that for the tumbleweed version.
    I'm really happy with the 13.2, (that's why I asked), but I must admit that I'm not an advanced user like you (I use thunderbird/firefox/eagle/freecad, and dlna services, and it not for my job (at work I'm running that I'm told to run :windows7 (I would prefer linux image )...
    BTW I love eagle too image, but I'm helpless for your problem.
    Guillaume.
  • craigarno
    craigarno over 10 years ago in reply to kikoun
    On 05/23/2016 12:15 PM, Guillaume barrey wrote:
    May I ask why you're using the 12.3 and not a more recent one ?
    Very simply, OpenSUSE has become quite unstable ever since Microsoft
    became a major shareholder and started directing development.
    I run a large number of services under Linux to support what I do.
    Upgrading usually means being out of business for 1 week to 1 month
    while I devote 100% of my time to fixing everything broken.  Last time I
    upgraded from 11 to 12, Asterisk didn't work for a week.  This meant I
    didn't have phone service for a week... not acceptable.  I listened
    carefully to others upgrading to 13 and heard all manner of woe, mostly
    email and php things breaking.  I rely heavily on email, run OwnCloud
    for Firefox Sync, Contact sync, Calendar sync to desktops, laptops, and
    phones... I use Dovecot for IMAPS to Thunderbird, SquirrelMail, etc.  I
    won't bother listing all the rest of what I run as it relates to heavy
    embedded systems development, hardware and software with revision
    control and database support. In other words I'm a heavy experienced
    user.  Linux is much more to me than a "Windows desktop replacement for
    my applications". It has to be stable and work, out of the box so I can
    do my own work instead of fixing someone elses work (which I do pro bono
    work occasionally for open source projects).
    From your description of 13.x stability it might be time to take the
    upgrade risk. I will have a backup plan, such as switching to Ubuntu or
    going back to 12.x if 13.x is still too messed up, or so heavily
    "modified" that I might as well be learning a new distribution... Kind
    of like why I switched from MS Office to OpenOffice/LibreOffice around
    2003, well that and OpenDocument format [international standard ISO/IEC
    26300].
    BTW, I really like Eagle, as it does a lot of things right.  That's why
    I'm here.
    Craig
  • craigarno
    26300].
    I'm here.
    Craig
  • craigarno
    26300].
    I'm here.
    Craig
  • craigarno
    26300].
    I'm here.
    Craig
  • kikoun
    I'm running Opensuse 13.2 x64, (KDE, Nvidia graphic driver) and I don't have any trouble like yours (all eagle 7,x.0 versions).
    Maybe there is some issues with some library of the 12.3 Opensuse version that are no more compatible with last Eagle version ...
    May I ask why you're using the 12.3 and not a more recent one ? I know that is not always a good idea to update to the latest  version but the 13.2 is very stable now.(unlike like the last 'leap' Opensuse version ...)...
    guillaume.
