EAGLE User Support (English) ulp status() that lasts after exit()
  • Views 850 views
I'd like my ULP's to keep the status() message after exit, with a
natural timeout, so I can give soft feedback without any requester
blocking the UI.
Is there an option for this now? It seems like the status bar always
gets overwritten with an ulp "ULP finnished" message.
Suggestion to discuss:Maybe this finnished message can be skipped when
the ulp is launched from a hotkey or context menu?
    autodeskguest over 10 years ago in reply to autodeskguest
    blocking the UI.
    Hi Morten,
    I think the idea of a timeout is very reasonable, since it doesn't hog
    the status line forever.
    The tooltips for the various commands also use the status line so it
    might be good to limit it to something like 5 seconds or so.
    Let me know what you think.
    I think 5s timeout, and/or interruption by other tooltip messages would
    be perfect. I don't think the ULP finnished message ever had any
    practical use for me, but I am not sure if you should remove it in all
    use cases. I wouldn't mind, but you better have a second thought.
    blocking the UI.
    Hi Morten,
    blocking the UI.
    Hi Morten,
  • rachaelp
    rachaelp over 10 years ago in reply to autodeskguest
    Hi Jorge,
    A timeout would work for me and likely very simple for the devs to
    implement so I'd be happy with that.
    Best Regards,
    Rachael
    blocking the UI.
    Hi Morten,
    Best Regards,
    Jorge Garcia
  • rachaelp
    Yes that's annoying when you can't see your final status() message. Maybe
    another way would be to have an option to disable the ULP finished message
    so final output message from the script itself remains until another action
    is performed?
