EAGLE User Support (English) Non-Existent Keepout
  • Subscribers 187 subscribers
  • Views 936 views
I'm using a back-rev version of Eagle, 6.5.  I've designed a library part
for a non-standard inductor with an odd shape and height.  There are only 3
items in the library for this part: 2 pads and a top keepout layer.
I've placed all my components on the board, did an ERC and a DRC, and there
are no errors.  Then I routed the board OK.  I was just moving around some
component names so they aren't on top of vias when I noticed a keep out
area on the top of my board.  After scratching my head, I realized the keep
out is from the inductor, but the inductor is placed on the bottom of the
board.  I confirmed that the keepout on the bottom of the mirrored part is
there, and that if I move the inductor the top keep out moves along with
it.
There's a FET sitting on top of the top keep out, so obviously the keep out
isn't doing anything, especially since DRC didn't complain.
Any ideas what might be causing this?  I'm guessing this is a display
problem and not a design problem.
Dave
    Hi Warren, Morten and Rob,
    Thanks for the replies.  I REALLY appreciate them.
    OK, Warren's comments did it.  I have to blame this on every one of my
    employee.  (Yes, singular is intended.)  Sorry, an inexperienced user's
    brain lock.  Though I turned layers on and off many times in the .brd, I
    didn't think of doing that in the .lbr.  DOH!
    Thanks again for enlightening me, and I apologize for having wasted your
    time.
    Dave
    autodeskguest over 10 years ago in reply to autodeskguest
    On 25/08/16 17:14, Dave Wills wrote:
    I should have added some pictures yesterday.  Here they are:
    The pictures clarify what you say, but what would really be useful is a
    copy of your library and board files.
    1 - Top and bottom view.  The inductor is sitting on the bottom side,
    underneath Q2.  The outlines of the top keepout in red and the bottom
    keepout in blue are visible.
    (I couldn't insert a 3rd image here.  It's called 1.png.)
    2 - Top view only.  Top keepout is still visible, and is not valid.
    3 - Bottom view only.  Inductor and bottom keepout are visible, and no top
    keepout.
    And just to be sure there weren't both top and bottom keepouts in the
    library part, I deleted the "top" keepout (bottom keepout when the part is
    mirrored to the bottom of the board), then moved the pads to make sure
    there were no other hidden elements to the part.  The only elements of the
    part are the 2 pads (each an SMD pad + some polygons to give the pad it's
    odd shape) and the one keep out rectangle.
    This is a bit confusing to understand what you mean. If you say both
    tkeepout and bkeepout are following the inductor when you move it, they
    surely must have been drawn like that in the inductor library component?
    t/bkeepout are independant layers, but they get swapped with the device
    mirroring.
    Open the ind package, make sure both t&bkeepout layers are enabled and
    try to move one. They may have the same or similar color and fill
    pattern when seen from the lib perspective.
    On 25/08/2016 12:26 p.m., Dave Wills wrote:
    it.
    Dave
    Hi Dave
    You may not be seeing what you think you are seeing. Is it really a
    tKeepout? It is a different size to the bottom keepout.
    Try a couple of things:
    Clear the DRC errors
    Type ERRORS CLEAR into the command line in the board editor.
    Did it disappear?
    Turn off the tKeepout layer in the board editor.
    Did it disappear?
    In the library turn on all layers.
    Is it there?
    That's all I have right now.
    If you have a paid version of v6.5 you should upgrade to the last
    version 6.6  here ftp://ftp.cadsoft.de/eagle/program/
    HTH
    Warren
    keepout.
