I'm modifying a previous design into something different. The original
design was laid out on a 4-layer board, but I'd like to lay out the new one
on a 2-layer board. I've set things up correctly on the layers tab in DRC,
but the Layers panel in the board designer still shows the internal layers,
and it gives me an error when I try to delete them ("Can't delete internal
layers."). Is there a way around this? If push comes to shove, is it safe
to just ignore the internal layers while I'm routing?
The reason I'm not creating a new design from scratch is that there's a
power supply section in the original design that was kind of tricky to
route, so I'd like to preserve it. Everything else is just airwires I'll
have to re-route. Thanks.
I'm running v4.16 on Win7 x64.
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
