EAGLE User Support (English) Deleting internal layers
  • Replies 13 replies
  • Subscribers 187 subscribers
  • Views 2013 views
I'm modifying a previous design into something different.  The original
design was laid out on a 4-layer board, but I'd like to lay out the new one
on a 2-layer board.  I've set things up correctly on the layers tab in DRC,
but the Layers panel in the board designer still shows the internal layers,
and it gives me an error when I try to delete them ("Can't delete internal
layers.").  Is there a way around this? If push comes to shove, is it safe
to just ignore the internal layers while I'm routing?
The reason I'm not creating a new design from scratch is that there's a
power supply section in the original design that was kind of tricky to
route, so I'd like to preserve it.  Everything else is just airwires I'll
have to re-route.  Thanks.
I'm running v4.16 on Win7 x64.
    autodeskguest over 10 years ago in reply to autodeskguest
    Thanks, Jorge.
    Thanks, Jorge.
    Compared to a new license, that's a very attractive price, but I'm having
    trouble finding out what's better about the 7.7 vs. 4.16, so I can't tell
    if it's actually worth it.
    Hi Karl,
    Here is my best shot at summarizing what has been added to EAGLE since
    V4.16. If I miss anything, hopefully other users will chime in.
    Differential Pair Routing with Length equalization
    XML File format for easy version control
    Assembly Variants
    Custom context menu entries
    2 sheets in the Freeware version
    Table of contents view in the library editor
    Arbitrary pad shapes in the library editor
    The ability to assign multiple pads to a single pin in the library
    Attributes(Maybe was in V4 I don't quite remember)
    Follow-me router
    Schematic Hierarchy(still needs work, but the future is bright)
    Infinite undo/redo list within a session
    Better resolution on the CAM processor by default
    Dimension tool
    Import existing EAGLE drawings into new ones (Design Reuse)
    Sheet thumbnails in the Schematic
    Design previews in the EAGLE control panel
    ACCEL-ASCII Import
    Bridges to LTSpice and PCBSim
    Net names show up on traces and pads in the layout editor
    This is everything I have off the top of my head, however I'm sure I
    missed a few things.
    Best Regards,
    Jorge Garcia
    Am 11.10.2016 um 18:01 schrieb Karl Lautman:
    Why do you have trouble finding that out? Just download the 7.7, extract
    its contents with your packer of choice and go straight to the doc
    folder. You'll find the file UPDATE_en.txt here (same as it is for your
    current 4.16r2 installation).
    Within UPDATE_en.txt, jump to the section "Release notes for EAGLE
    4.16r2". From here, you can read the file back up to the top (skip the
    "Bugfixes" sections while reading).
    Alternatively, read the release notes online (menu on the right side):
    https://cadsoft.io/resources/
    As far as I can tell, the update is definitely worth it. In short: The
    jump from 4.1 to 5 is a HUGE one, contains many must-have features. The
    jump from 5 to 6 is not quite that exciting, but once again you'll get
    some nice new features. V7 is V6 with increased version number.
    Rene
    Not too long ago I read somewhere in the newsgroups that every step up
    needs a fee which seems also to be logical to me.
    Hi Joern,
    This was the case under Farnell, things are different under Autodesk :).
    So do I understand you right that for example an upgrade from Version
    4.16 to version 7.7.0 cost one fee only? (which is around €600.- for a
    professional (ultimate now?))
    If that is so it would certainly catch the interest of users image
    You are understanding correctly. As Karl has already discovered.
    Best Regards,
    Jorge Garcia
    There's an upgrade quoter https://cadsoft.io/pricing/ (bottom of the page).
    Based on my license number, it says my cost to upgrade from 4.16r2 Pro to
    Ultimate (presumably v7.7) is $US 541 (about 600 euros).  It doesn't
    indicate any other fees.
    Am 10.10.2016 um 18:50 schrieb Jorge Garcia:
    On 10/8/2016 3:22 AM, Joern Paschedag wrote:
    Am 07.10.2016 um 17:59 schrieb Karl Lautman:
    the autorouter is for the birds
    Which is why I avoid it.  Plus, I actually enjoy the routing process.
    Can you think of any other reasons to upgrade?
    Don't ask ME image
    It certainly depends on what you need/want.
    If you upgrade from 4 to 5 you pay the upgrade fee, if you upgrade from
    4 to 6 you pay twice the fee and so on.
    Hi Joern,
    Just to clarify this policy has changed. There's no multiplier anymore
    so everyone pays the same flat upgrade fee.
    hth,
    Jorge Garcia
    Autodesk Support
    Hi Jorge,
    thanks for cutting in.
    Joern Paschedag
    Don't ask ME image
    Hi Joern,
    hth,
    Jorge Garcia
    Autodesk Support
    Don't ask ME image
    4 to 6 you pay twice the fee and so on. You should check the release
    notes at the cadsoft site and then decide what you really need.
    As I have checked the site I noticed that you cannot straight download
    versions before 7
    anymore. You have to do that on the cadsoft ftp site. I would do that
    NOW and download
    ver. 5.15 and 6.6.0 for your system, because I think that will not be
    possible anymore in near future. You can then license the version you want.
    You may have noticed that cadsoft/eagle has been resold from Farnell to
    Autodesk
    Imho their policy is even more worst than was Farnells. I shall not
    accept their License and Services Agreement and I don't like the
    Autodesk Privacy Statement at all.
    Apart from that I think that for the upgrade fee from ver.6  to 7 the
    real achievement is far too less.
    Joern Paschedag
