EAGLE User Support (English) Unwanted vias automatically added
  • Replies 8 replies
  • Subscribers 187 subscribers
  • Views 762 views
Look at the attached image set
1. I am coming in with a diff pair (purple) and I want to end up at the
vias.
2. I want to do a stop here and follow the yellow wire in to the via.
3. This is the peculiar result I get when I click here. Eagle usually
doesnt add vias automatically, so why does that happen? Not to mention,
why are they offset from the click point?
I suspect this issue is related to other weird via behaviour, like the
other threads with title "Grabbing airwires on routing" and "Change
layer issue" written by me.
    Hi Morten,
    I've created a bug report for this one with Video.
    Best Regards,
    Jorge Garcia
    Hi Morten,
    Best Regards,
    Jorge Garcia
    Hi Morten,
    Best Regards,
    Jorge Garcia
    vias.
    Hi Morten,
    Could you send me an example file of this to play with?
    This is one of those things that a video and file makes it really clear
    to the devs what the issue is. Considering that there are now more devs
    to explain issues to this would be helpful.
    Best Regards,
    Jorge Garcia
    There is not much too it.. This simple board will do it.
    vias.
    Hi Morten,
    Best Regards,
    Jorge Garcia
    On 27/10/2016 7:06 p.m., Morten Leikvoll wrote:
    There is inconsistancy if diff wires add vias when it meets the same
    signal, when single end wires doesn't. I don't really care if its
    documented. I think it is wrong.
    At least I need a clear explanation why it has to be like that, but I
    don't think it exist. We have the shift+click function to add vias on
    single end routes, so why not use the same for diff pairs?
    If that's the complete story, then I agree.
    Warren
    On 27.10.2016 01:36, Warren Brayshaw wrote:
    Hi Morten
    The generation of the vias will be correct but the placement of the lower
    added via needs an answer.
    From the HELP > ROUTE
    "If you route towards the wire end points of a Differential Pair in a
    different layer, and the wires are fully aligned, the proper vias will be
    generated automatically."
    So your hover/click aligned wire endpoints on a different layer, hence I
    would expect vias to be created. The via is placed to retain the clearance
    between the pairs so the upper one is placed correctly.The edge of the via
    aligns with the edge of its trace.
    The lower one normally would have gone vertically down but there may be
    another signal it is retaining its clearance from. If that's not the case
    then there is a problem.
    Attached - The red via is where it would normally go. Probably keeping away
    from the vertical blue signal.
    Regards
    Warren
    Hi Morten
    Regards
    Warren
