EAGLE User Support (English) EAGLE vs Altium CircuitS tudio
  • Replies 18 replies
  • Subscribers 189 subscribers
  • Views 3284 views
It looks like EAGLE's newest competitor is Altium's CircuitStudio (CS)
which now sells for $995 (it used to sell for $3500 before AutoDesk bought
EAGLE). This is just a little more than EAGLE's mid-range package ($820)
and cheaper than EAGLE's full-range package ($1640). One of the features I
liked in the demo was the push-and-shove manual router. It also imports
EAGLE v6 and above files. It may have an annual subscription fee, but I
don't know how much that is.
I was wondering how AutoDesk plans on meeting this threat.
http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
    On 12/26/2016 12:26 PM, Neon John wrote:
    On Mon, 19 Dec 2016 10:16:27 -0500, "Reece R. Pollack" <reece@his.com>
    wrote:
    It runs only under Windows, and while there is a free 30-day trial there
    isn't a hobbyist version. If I switch from Eagle I'll most likely go to
    KiCad.
    Eagle selling out to AutoDesk followed by the new licensing scheme was
    the straw that broke the camel's back for me.
    Products and companies get sold. Premier Farnell bought CadSoft in 2009;
    Autodesk bought it in 2016. Neither of these sales has affected my
    willingness to use the product. The one project I'm contemplating doing
    with KiCad is because the low-density, 2-layer board needs to be a fair
    bit larger than 100mm x 160mm.
    I have to ask, what in the "new licensing scheme" do you object to? They
    seem to have simplified the commercial offerings to the most common.
    Rather than being totally ala carte, you start with a choice of whether
    you want the autorouter or not -- most professional layout folks I've
    talked with never use an autorouter. Then you get the choice of a
    standard Eurocard size or the unlimited version.
    Finally you choose how many users you're licensing. Even the "Ultimate
    LS" package with 10 licensed users is less than $3,500 (USD); the
    equivalent entry-level Mentor PADS product is $5,000, and Altium
    Designer starts at $7,500.
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    Can you elaborate on this? As far as I can tell the only change to the licensing is they renamed what the various editions were called to be in line with their other products and increased a couple of the allowed board areas on the cheaper products. For me all I can see is a company with huge resources at their disposal throwing a lot of effort into moving EAGLE forward after it had several years of resource starvation. Personally I am very happy Autodesk bought EAGLE and I can't wait to see what the next major version brings.
    Anyway, good luck with your move to KiCAD, I'm sure all the resources CERN have been putting into it have made it a good product.
    Best wishes,
    Rachael
    KiCad.
    I had tried KiCAD several years ago and found it not quite ready for
    prime time.  I downloaded the current version to Ubuntu Linux 2 weeks
    ago.
    Wow, what a few years and CERN's money can do.  Using a fairly simple
    board and starting from scratch, I entered the schematic and laid out
    the board in 2 days.  I'm going to do our most complex board this
    week.  If that goes smoothly, I'm going to convert us over
    company-wide.
    John DeArmond
    http://www.neon-john.com
    http://www.tnduction.com
    Tellico Plains, Occupied TN
    See website for email address
    On 12/20/2016 09:25 AM, David Pollum wrote:
    reece wrote on Mon, 19 December 2016 15:26
    On 12/18/2016 12:28 PM, David Pollum wrote:
    I was looking for CircuitStudio's limitations while writing my previous
    posting, but of course didn't find them until after I clicked "Send":
    "What are CircuitStudio's design limitations?
    CircuitStudio supports:
         Unlimited components.
         Unlimited nets.
    While there are no 'hard limits' per se, the software has been
    engineered to make it impractical for use with large designs. To this
    end, the PCB Editor will start to exibit performance degradation when
    editing designs containing 5000 pads, becoming virtually unusable with
    designs containing 50,000 pads. Degradation itself takes the form of
    progressive slow-down in PCB editing functions (such as routing,
    placing
    components, polygon pours, etc)."
    reece;
    Just curious, but where did you find those limitations listed?
    The limitations are described at in the last item on this page:
    http://documentation.circuitstudio.com/display/CSTU/CircuitStudio-((FAQs))
    The license is described here:
    http://www.newark.com/altium/11-100-15-1-e/circuitstudio-commercial-license/dp/47Y0246
    autodeskguest over 9 years ago in reply to rachaelp
    rachaelp wrote on Mon, 19 December 2016 15:47
    Hi Reece,
    Element14 thought your replies were so good it repeated them three
    times each for effect! :d I think I'll stick to Eagle Central for
    replying on here as it seems they've messed things up again!
    Seriously though, all good points and illustrate why it's not really a
    like for like comparison.
    Hi David,
    You ask what Autodesk's plans are to meet this threat, well you should
    look at some of the blog posts from Matt Berggren since they took over.
    He's given more than a few hints that they're really building up the dev
    team and are working on a lot of improvements in EAGLE. I'm very hopeful
    that the future for EAGLE under Autodesk, with all their massive
    resources and ability to finance development, will be significantly
    brighter then it has been. It should be noted that Matt was with Altium
    before moving to Autodesk so he's very familiar with the Altium EDA
    offerings.
    Best Regards,
    Rachael
    Rachael;
    I forgot that Matt had been with Altium. It will be very interesting to see
    what Autodesk has in store for EAGLE.
         Unlimited nets.
    placing
    reece;
  • omega-5
    omega-5 over 9 years ago in reply to rachaelp
    Am 19.12.2016 um 16:47 schrieb Rachael:
    Element14 thought your replies were so good it repeated them three times
    each for effect! :d I think I'll stick to Eagle Central for replying on
    Grin from ear to ear.
    Freundliche Grüße / Kind regards
    Friedrich
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
    ... or http://www.eaglecentral.ca
  • rachaelp
    Hi Reece,
    Seriously though, all good points and illustrate why it's not really a like
    Hi David,
    You ask what Autodesk's plans are to meet this threat, well you should look
    at some of the blog posts from Matt Berggren since they took over. He's
    given more than a few hints that they're really building up the dev team
    and are working on a lot of improvements in EAGLE. I'm very hopeful that
    the future for EAGLE under Autodesk, with all their massive resources and
    ability to finance development, will be significantly brighter then it has
    been. It should be noted that Matt was with Altium before moving to
    Autodesk so he's very familiar with the Altium EDA offerings.
    Best Regards,
    Rachael
  • rachaelp
    Hi Reece,
    Hi David,
    Best Regards,
    Rachael
  • rachaelp
    Hi Reece,
    Hi David,
    Best Regards,
    Rachael
