EAGLE User Support (English) Error using Mirror tool.. ...
  • Subscribers 189 subscribers
  • Views 1325 views
Hi All,
I'm using Eagle v6.6.0 standard edition, and I'm encountering an error when
I try to move a component to the backside of the board using the mirror
tool. The error is "The Standard Edition of Eagle cannot perform the
Requested operation", and "Some objects extend outside the allowed board
area".
My board size is 5" x 3.5", and the component easily fits on the frontside
of the board and Eagle is happy about it. The component outline itself is
3.7" x 2.8", so it seems like in the act of mirroring that Eagle perceives
the component to be outside the allowable area?
The component in question is for a GLCD module, and simply consists of a 20
pin header, 4 mounting holes, and the part outline.
EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    warrenbrayshaw wrote on Wed, 06 September 2017 11:38
    Click the MOVE icon
    Click on the element you wish to move
    At this point the Element is stuck to the mouse.
    Then, in the 'Parameter Toolbar' click on 'Mirrored'
    The element is now mirrored on the mouse
    Lastly place the element where you need it, within the edition
    constraints
    Yes that works too...
    John,
    My post explained why mirror didn't work in your situation and how to fix
    it so that it does (I make all my components centred on their origin so
    that rotate/mirror work reliably) but Rob and Warren are quite right that
    the best solution in your case is simply to use the MOVE command and use
    its inbuilt mirroring capability. Sorry if my oversight made you alter your
    component unnecessarily....
    Best Regards,
    Rachael
    autodeskguest over 9 years ago in reply to rachaelp
    On 6/09/2017 6:22 a.m., rachaelp wrote:
    CadSoft Guest wrote:
    Don't use the mirror tool directly. Use the "MOVE" tool to pick it up,
    then click the middle button to mirror it and move it back onto the
    valid board area before placing it.
    Yes that's a good suggestion! Except if you are using a mac and have no middle button of course....
    Click the MOVE icon
    Lastly place the element where you need it, within the edition constraints
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
  • rachaelp
    autodeskguest over 9 years ago in reply to e14 Contributor
    On 05/09/17 16:50, jmorley@endeavour-usa.com wrote:
    Hi Rachel,
    OK, many thanks! Yes, the part has its origin at one corner, so I'm sure
    that is what is going on! This origin location is desirable for placement
    purposes, but I can work around that issue as long as I can get the part on
    the backside!
    e14 Contributor over 9 years ago in reply to rachaelp
    Hi Rachel,
    the backside!
  • rachaelp
    Hi John,
    Is the package centred on it's origin or has the package been created with the origin on one corner? If it's been placed on a corner then mirroring it will mirror it on that corner such that part of the part would end up partially outside the board. If this is the case then you'll need to edit the part to centre it so that when it's mirrored it mirrors about its centre and sits directly below where it was on the bottom side.
    Best Regards,
    Rachael
