Forum Have a question about CadSoft EAGLE?  Ask our Expert, Richard! (Archive)
  • Replies 1129 replies
  • Subscribers 245 subscribers
  • Views 51285 views
  • eagle
  • expert
  • richard_hammerl
  • cadsoft
nlarson
nlarson over 16 years ago
This thread is now locked - but you can still ask Richard by posting your questions here.  If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Browse past Q&A help on anything technical relating to CadSoft EAGLE!
Richard Hammerl
Richard is an engineer with 16 years experience in EAGLE customer support and is waiting for your questions.
  • Jorge_Garcia
    Jorge_Garcia over 15 years ago in reply to e14 Contributor
    Hi Chris,
    Tim is correct, ExpressPCB uses a closed proprietary format which EAGLE nor any other ECAD program can import. The only real option if you want to have the design in EAGLE is to recreate them from scratch.
    hth,
    Jorge Garcia
    Cadsoft Support
    I won't try to speak for Eagle, but we use both at my shop, and our understanding is that ExpressPCB files are in a fairly proprietary format and cannot be used with any other ECAD system.
       I've been prototyping in expressPCB software and would like to try to move the design into EAGLE.  Is there a way to do this?  I'm not finding it if there is.
    Chris King
    e14 Contributor over 15 years ago in reply to Jorge_Garcia
    Hi Jorge, I guess I'd become so used to dealing with single sheets that I missed the option in the print dialog. I answered my own question here.
    Andy
  • Jorge_Garcia
    Hi Andy,
    Double check the settings in the Print dialog, I tried with a 10 page schematic and was able to get all of the schematic sheets into the PDF. There's no need for a ULP, make sure that you select the All option under the sheets section.
    hth,
    Jorge Garcia
    Hi Jorge,
    Using the File-> Print and output to PDF creates a PDF of the current sheet only, not the 3 I have setup. I wonder if there's a ULP to allow me to output this, although I'd see it as pretty core functionality.
    Any further advice welcome.
    Andy
    Jorge,
    Thanks, I was trying to keep all of the attributes assigned to the resistors
    intact.. it turns out the replace command works fine.
    Cheers
    Steve
    Steve Young, CTO
    BAM Labs, Inc
    170 Knowles Dr. #207
    Los Gatos, CA 95032
    408.335.5021 W
    408.499.6385 C
    Sent: Friday, September 02, 2011 1:38 PM
    To: bamlabs
    Subject: - Re: Have a question about CadSoft EAGLE? Ask
    our Expert, Richard! [1437eu-1i0m-s6q]
    image: element14<http://www.element-14.com?CMP=e14notificationemail_header>
    Re: Have a question about CadSoft EAGLE? Ask our Expert, Richard!
    created by Jorge_Garcia<http://www.element14.com/community/people/Jorge_Garcia>in
    CadSoft EAGLE - View the full
    discussion<http://www.element14.com/community/message/36530#36530/l/re-have-a-question-about-cadsoft-eagle-ask-our-expert-richard
  • Jorge_Garcia
    Hi Andy,
    As far as I know File-> Print with the printer set to be Print to File(PDF) should allow you to print a multi-page pdf.
    Let me know what you've been doing and maybe I can provide more useful information.
    hth,
    Jorge
  • Jorge_Garcia
    Hi Mostcosmos,
    I hope you are doing well. What happening here is that because you have that pin set as a power pin EAGLE expects a supply symbol to be connected to it and not a net(I'm almost certain you have net connected to it), that's why EAGLE flags the warning. Feel free to ignore it, it won't create any problems on your finished board.
    hth,
    Jorge
  • Jorge_Garcia
    Hi Wouter,
    Right now the best way is to not save the autorouter's work, as you already know. Once saved there's isn't an easy way to take remove the autorouter's work.
    Hopefully, version 6 will provide a better solution to this problem.
