Forum Have a question about CadSoft EAGLE?  Ask our Expert, Richard! (Archive)
  • Replies 1129 replies
  • Subscribers 245 subscribers
  • Views 51095 views
  • eagle
  • expert
  • richard_hammerl
  • cadsoft
nlarson
nlarson over 16 years ago
This thread is now locked - but you can still ask Richard by posting your questions here.  If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Browse past Q&A help on anything technical relating to CadSoft EAGLE!
Richard Hammerl
Richard is an engineer with 16 years experience in EAGLE customer support and is waiting for your questions.
  • Dusan_R
    Dusan_R over 14 years ago in reply to Richard_H
    Hi Richard,
    do you have any idea why, though the Snap length is set to 0.5mm, 6.1 leaves
    tens of short airvires (0.06mm long and so) and do not connect it to the
    pads??? Must be connected manually and I have to click lot of times trying
    to hit the pad as exacly as possible, making unwanted bundles at the ends of
    wires. What's interesting, sometimes Snap obviously works, sometimes it is
    nearly impossible to finish the connection. Oh my God, have anybody tested
    6.x before it was released??? Really horrible "upgrade"...
    And please, do not recommend me to try beta version, I need to go forward,
    not to test for free and on hot data the software I have purchased. I am now
    working in both 6.1 and 5.11 and it is really a big relief to go back to
    5.11, but it is quite uncomfortable to keep all data separated and not
    damage anything with 6.1.
    I think CadSoft have lost a lot of its good name, pity.
    Dusan
  • Dusan_R
    Hi Richard,
    I think SNAP doesn't work, at least with SMDs - difficult to hit the SMD
    center even with large Snap length
    Dusan
    Hi Richard,
    I´ve got a doubt making the gerber files:
    You can only place a pad in the package libraries and you can only insert the vias in the board layout. The difference between them is that a pad must be covered with cooper to join it to another track, so it must avoid the "cream frame " (green layer to protect/isolate the board), and the via don´t need that. But when I see (in the came processor) the different gerber files , specially the solder stop mask and the cream frame (layers 29,30,31,32) there is no difference between a pad and a via.
    Xabi
    e14 Contributor over 14 years ago in reply to Richard_H
    Hi Richard,
    thank you so much for your advises.
    It has been quite difficult to understand how to add the section in the CAM job, I'm not too familiar with this.
    I think I did it properly. I have to find a kind of manual that contains a detail explanation about CAM processes?
    kind regards,
    Sylvain
  • Richard_H
    Richard_H over 14 years ago in reply to Dusan_R
    Hi Dusan,
    please tru to open, than make ERC (OK), pinswap any port connections .................and repaet ERC (again OK) . Now UNDO and again repeat ERC - the consistency is lost and connections
    mismatched in SCH
    I see the problem.... forwarded to our development team.  Thanks,
    Richard
  • Richard_H
    Richard_H over 14 years ago in reply to e14 Contributor
    Hi Xabi,
    I'ld take a polygon, draw it around the pads and name it the same as the signal name which is connected to the pads. You can switch off the Thermal option of the polygon when you want a solid connection to all pads.
    Hope this helps.
    Richard
  • Richard_H
    Hi Dusan,
    Another minor bug: if I use PINSWAP, the first selected pin is not highlited at its real position, but in  the other part of drawing relative to (0 0) instead to the device origin. Minor bug, but I think there are still too much similar bugs in 6.1, lot fo them much serious (primarily the sudden consistency losses are quite annoying)
    this problem is already reported to our development team. We will fix it as soon as possible.
    Sorry for wasting your time, perhaps some as bug report thread would be worthy in the forum.
    It's no waist of time. Each problem reported helps us to imporove our software.
    Richard
  • Dusan_R
    Hi Richard,
    I have made a sample file:
    please tru to open, than make ERC (OK), pinswap any port connections (say
    P2.0 - P2.1) (the swaplevel was temporarily changed on all ports to 1 to
    obtain a possibility to optimize layout) and repaet ERC (again OK) . Now
    mismatched in SCH - can be only fixed in XML files or by deleting IC1 and
    placing again (i naven't found other way). Try to SHOW swapped-unswapped
    nets - it really doesn¨t look as correct behaviour!
    Dusan
  • Dusan_R
    Hi Richard,
    thank you for the information.
    Yes, I agree that XML gives some advantages (I also have fixes some of the
    consistency losses direcly in XML) and that EAGLE is (or was?)very modest as
    to the memory/disk apace requirements, but though I would appreciate the
    option binary/XML - but this is not a problem for me.
    If I am reverting to 5.11 now, it is not forever, but only until the bugs
    will be fixed - world is going forward and one can't stay on place. I think
    6.1 is not mature yet and if you are scheduled, it is better to stay in 5.x.
  • Richard_H
    Hi Dusan,
    you wrote:
    I copy elements using COPY it is quite difficult to place part correctly - it tends to snap to the neighbouring grid position (in all directions), so sometimes I have to undo and try again several times until I place element correctly.
    This is a problem which is already fixed in version 6.1.1, the current beta.
    BTW, I think that it would be great to have the possibility to back-convert the data or to have the option to save binary too (also because of much smaller files).
    The XML data structure offers lot of benefits which are not at once visible. But I am sure that XML gives big incentive for the future. We feared that XML data would be ten times more than the binary data, but it is "only" about 5 times more. Depending on the contents, of course. Today we are in the lucky situation that it is no longer so important whether you have a 200k file or 1Mbyte. Compared to other applications EAGLE is very modest.
    Talking about reverting to the previous version: You could try two ULPs: export-board.ulp and export-schematic.ulp from the cadsoft.de download area. This might work.
    Richard
