Forum ULP connect check to HTML
  • Subscribers 189 subscribers
  • Views 1006 views
  • html
  • ulp
  • check_connections
I have used a ULP to check connections on all ICs, connectors, res, and caps, but have missed placed it. I found the output format very helpful, html. I have looked through the ULP download section at cadsoft with no luck, any help would be appreciated.
Cy Drollinger
ER LLC
    0 e14 Contributor over 16 years ago in reply to Richard_H
    Yes I have seen the part2html, cute little app. I have used a ULP, now that I think about it, likely parsed a netlist and put the output into html. I was able to check all signals and there connections, very handy.
    Cy
    ER LLC
  • Richard_H
    0 Richard_H over 16 years ago in reply to e14 Contributor
    Hi Jason,
    you are absolutely right.... Sorry, I did not realize that Cy wrote about HTML and not about HPGL...image
    The only ULP I know about is part2htm.ulp that outputs a partlist in HTML format.
    Richard
    HTML and HPGL are pretty different.
    HTML is, basically, a web page, and HPGL will be a plotter output.
    I think Cy wants to view the report in a web browser.
  • Richard_H
    Cy,
    I am not sure what your problem exactly is, but it is possible to output HPGL with the help of the CAM Processor.
    Perhaps this helps.
    Richard
  • huayuliang
    0 huayuliang over 16 years ago
    do you want use ulp output HTML file?
