Forum Solder mask thickness
  • Views 561 views
  • pcb
  • standard
Skysurfer_14
Skysurfer_14 over 16 years ago
we actual have a problem with a product, because the solder mask of the PCB has higher thickness then the copper. Now I'm looking for rules or standards describing this. Where can I find this?
Best Regards,
  • Skysurfer_14
    0 Skysurfer_14 over 16 years ago in reply to Richard_H
    Hi Richard,
    thank you for your answer, but I cant ask my board manufacturer since he would say that everything is OK!
    But I found the applicable standard: IPC-SM-840D "Qualification and Performance Specification of Permanent Solder Mask".
    Best Regards
  • Richard_H
    0 Richard_H over 16 years ago
    best would be to talk to your board manufacturer.
    Maybe this link helps:  www.avx.com/docs/techinfo/smzero.pdf
    Richard
