Autodesk EAGLE
Autodesk EAGLE
Documents Atmel CAD Library for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 30 Apr 2012 2:50 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:45 AM
  • Views 13960 views
  • Comments 19 comments
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a wide range of Atmel device categories like Microcontrollers, Memory, Sensors, Power Management, RF IC's, Transceivers etc. This library is provided in a downloadable ZIP format which includes below files:
1. Atmel Library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
imageAtmel_Library_Components_List.pdf
Atmel.zip
  • transceivers
  • eagle
  • ic's
  • management
  • sensors
  • footprint
  • library
  • microcontrollers
  • memory
  • cad
  • rf
  • power
  • symbol
  • cadsoft
  • atmel
  • mountaindude
    mountaindude over 12 years ago +2
    Looks like the download links are broken... All I get when clicking either of the above links is an "Error: An general error occurred while processing your request. " Might be worth looking into.
  • iha@via.dk
    iha@via.dk over 10 years ago +1
    I am missing component for ATSAMS70J21, can somebody help me?
    e14 Contributor over 10 years ago +1
    Nice library; although the ATSAM D series are missing. Any chance to see them add to the library? Is there anything that I can use as starting point for the SAM D, and modify it? I just started with Eaglecad…
  • megawattz
    megawattz over 6 years ago
    Downloaded this library today, thanks!
    shabaz over 7 years ago in reply to kr00t
    Hi Kristopher,
    You didn't specify the desired package outline, but standard EAGLE comes with ATMEGA168 in DIL28. That part has the same pinout as the 328p, so could be used interchangeably (if you're using the DIL28 package).
  • kr00t
    kr00t over 7 years ago
    I may be loading the library incorrectly, but I cannot find the 328p. That's the most popular atmel chip for the demographic of your viewer base. Perhaps I'm missing something.
  • jhoyland
    jhoyland over 7 years ago
    Really comprehensive library but seems to be missing the ATTiny88 which is unfortunate since that's the one I was looking for :-(
    Hello I am searching library for ATSAM G Series.(M4 MCU) I saw this library but it doesn't have it. Where can i find it ?
    Thank you in advance ..!
    e14 Contributor over 10 years ago in reply to e14 Contributor
    I am interested in the ATSAM D series too.  I am using the M0 Arduino board.
    Nice library; although the ATSAM D series are missing. Any chance to see them add to the library? Is there anything that I can use as starting point for the SAM D, and modify it? I just started with Eaglecad today.
  • 4jochen
    4jochen over 10 years ago in reply to iha@via.dk
    Did you create or find it.
    I start today creating my own. But like to avoid double work.
    Maybe you can share your creation or findings with me.
    Thanks very much, best regards,
    4Jochen
  • iha@via.dk
    thanks for the library..
