Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Cannot generate BOM
  • Locked Locked
  • Replies 17 replies
  • Subscribers 89 subscribers
  • Views 5938 views
  • frontpage
Cannot generate BOM
myrek021
myrek021 over 7 years ago
I have an annoying problem for which i need to find a solution quickly.
I cannot generate BOM on any of my existing or new projects. When I try to generate the bom or click "configure" I get the following error:
I recently moved from a win7 x64 system and have never experienced the problem on that machine.
Currently I'm running CS 1.4 on a win10 Professional X64 system. Could this problem be OS related?
I have tried reinstalling 1.4 version and also tried removing all preferences using the built in uninstaller but the problem remains.
I have just purchased an additional license renewal but the delivery time of 2-3 days for a license is a joke...
Any ideas on how to fix this issue would be much appreciated. Thanks!
  • e14softwareuk
    0 e14softwareuk over 7 years ago in reply to myrek021
    Thanks for the screenshot.
  • e14softwareuk
    0 e14softwareuk over 7 years ago in reply to e14softwareuk
    Over the weekend I got chance to try CS on a brand new installation of Win 10 Pro 64-bit (an ISO for October update from memory) that did not have MS Office installed (no office suite of any type). I was able to export a CSV BOM, in my testing I actually did this from the BOM Configure and then Export option.
  • myrek021
    0 myrek021 over 7 years ago in reply to e14softwareuk
    Hi Peter,
    I have now tried uninstalling office365 and this "solves" the problem. I do no longer get the error message and is able to export the BOM in .CSV or .TXT
    When i reinstall office365 32-bit or 64-bit the problem comes back.
    So this is not a fix since i need to have office and CS installed all the time but at least I know CS seems to have a problem with Office for some reason.
    Any ideas on what could fix it?
  • e14softwareuk
    Very interesting finding regarding office365. I will try and reproduce tonight on the clean Win 10 install I have. Is anyone out there successfully running offiec365 with CircuitStudio?
  • myrek021
    I hope you are able to re-create this problem and find a solution.
    All my colleagues are running CS on win7 x64 so i cannot test it on any other machine here. Thanks
  • e14softwareuk
    Finished testing and I'm sorry to say it seems to work perfectly. Generated an Excel BOM using BOM Simple.XLT template from example project PCI Express 4 Port Serial Interface. Installation order was CS followed by Office.
    • CircuitStudio 1.5.1 (Build 13)
    • Windows 10 Pro 64-bit, Version 1809, OS build 17763.107
    • Excel for Office 365 MSO (16.0.11231.20164) 32-bit
    A couple of suggestions:
    • Delete (or move to another folder) your own OutJob file and then try configuring and generating BOM again
    • Try using the example project as I did above
  • myrek021
    After investigating further I started uninstalling one program at a time until I got it working.
    It turns out it was kutools addon for excel that was the cause of this problem (at least i think so)
    Now Bom generation works again. Thanks for the time invested in this case.
