Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog CT Component Analysis
  • Author Author: sleuz
  • Date Created: 4 Oct 2012 7:05 AM Date Created
  • Views 846 views
  • wurth_electronics
  • r&d
  • ct
  • mrt
  • technology_center
  • wurth_elektronik
sleuz
sleuz
4 Oct 2012
Shooting x-rays and a continuous spectrumimage
Get inside...
Ever wanted to take a look inside your component? Shielded versions and various coverings prevent you from knowing what your product´s interior looks like and therefore how it actually operates.  This can be quite frustrating  especially when facing a  technical issue.
"more than you expect"
Würth Elektronik is using the latest technology to safe guard components from unnessesary "surgery" and achieve better results in testing and quality control. Offering additional service beyond the actual component is one of their top priorities.
They have established a technology center in Waldenburg, Germany which includes new test laboratories and R&D facilities. Amongst other high-tech machinery, the computer tomograph with a Nanofocus tube is definitely the highlight of the technology available. Würth Elektronik is able to reveal the set-up of any component without damaging or destroying it.
Shooting rays
The CT is shooting X-rays with a continuous spectrum through the component and is detecting the resulting intensity on an area-detector. As each material filters the X-rays differently, this will result in a different measured intensity and so in different shades of black and white. By rotating the component within the machine and taking picture by picture over a range of 360°, a volume of single pictures can be generated. Then by remodeling the single pictures with pixels, a volume model with voxels (voxel = volume pixel) is created. This happens via interpolation of multiple pixels to a single voxel and so a digital copy of the component is generated.
Taking advantage
Having a fully-rotatable 3D model leads to several advantages for engineers like receiving actual data from the component and better information due to a complete well-rounded check, as well as its high pace . So the from-simulation-to-design time will be built in real life and actual state of the component.
Here is a clip of a shielded power inductor from the WE-SPC series from Würth Elektronik taken by the computer tomograph.
Want to find out more about Würth Elektronik...come visit www.we-online.de
follow Würth Elektronik on element14
imageApplication Mindmap_Electromechanical Products.pdf
imageApplication Mindmap_Passive Products.pdf
imageProduktmatrix_SMT Power Inductors.pdf
imageWurth_Elektronik_One-Click_Selection_Guide.pdf
