Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog Simple design tips that will cool down the temperature of your PCB
  • Author Author: Würth Elektronik
  • Date Created: 21 Jul 2023 9:43 AM Date Created
  • Views 1532 views
  • Likes 8 likes
  • Comments 10 comments
  • pcb
  • design_tips
  • würth elektronik
  • pcb design
Würth Elektronik
Würth Elektronik
21 Jul 2023
> Video Link <
by Alexandre Chaillet
Temperature increase is a natural behavior of electricity. Each component has a resistance and each resistance release heat with current.
This is of course the case for connectors and PCB traces. A designer needs to choose his connector and traces cross section to have as less heat as possible. But not oversize them for a question of space and cost. Arrhenius law says that increasing of 10°C the temperature of a PCB roughly divides by 2 the life span of electronic components.
Easy to understand that the lowest is the best !
The video shows the exact same trace cross section, connector, wire size and current (in serie). The real duration is 11minutes. But on each type of sample, the configuration is different. It is fully obvious that each configuration release heat in a different way.
Add ground layer, thermal vias, tin on traces or thermal management stickers will have a very big impact on the temperature.
And so easily increase your products life span !
  • fralex
    fralex over 3 years ago in reply to ggabe
    of course, as you noticed, impossible to reach that in 10s, real duration s it is written in the article is 11mn to reach thermal stabilization
  • fralex
    worst case (hottest) is of course most red one and best (coolest) is grey color. best case is traces with additionnal ground layer, thermal vias around traces and also thermal manageent products from Wurth Elektronik to dissipate more thermal calories
  • cstanton
    cstanton over 3 years ago in reply to Würth Elektronik
    Looks good!
  • Würth Elektronik
    Würth Elektronik over 3 years ago in reply to Fred27
    hi ggabe , yes the time was 11 minutes.
  • Würth Elektronik
    Würth Elektronik over 3 years ago in reply to cstanton
    Hi cstanton , I uploaded the picture again is it now working fine for you?
