Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Forum 10BASE-T1L, PoDL, Single Pair Ethernet
Join Würth Elektronik to participate - click to join for free!
  • Replies 13 replies
  • Subscribers 78 subscribers
  • Views 7346 views
  • inductor
  • wurth_elektronik
suresh11
suresh11 over 4 years ago
Hello
I am implementing Power over Data Line in my 10BASE-T1L project. I checked the Würth Electronics webinar video on YouTube "Single Pair Ethernet filter design for industry". The following picture is taken from that [presentation](https://www.we-online.com/web/en/index.php/show/media/06_passive_components_-_custom_magnetics/events_1/webinar_videos/2021_webinars/Single_Pair_Ethernet_Filter_Design.pdfhttps://www.we-online.com/web/en/index.php/show/media/06_passive_components_-_custom_magnetics/events_1/webinar_videos/2021_webinars/Single_Pair_Ethernet_Filter_Design.pdf).
Here, a differential mode inductor is used to inject/takeout DC power on the line. What should be the minimum value of coupled inductor (U3 & U4) for class power (IEEE802.3cg class 10-12)? This might be quite a simple question, but I am very new to circuit design.
Regards
Raj
  • Würth Elektronik
    Würth Elektronik over 4 years ago +5 suggested
    Hi suresh11 , my collegue says you can use this one: https://sg.element14.com/wurth-elektronik/7448990470/inductor-47uh-2-3a-20-coupled/dp/2842138 Hera also a suited appnote for you: https://www…
    shabaz over 4 years ago +1
    I don't know the answer but perhaps 20 uH as a minimum is a reasonable first guess start for your tests. It would provide 1k impedance, I don't know if that's enough, but seems a good starting point to…
  • suresh11
    suresh11 over 4 years ago in reply to Würth Elektronik +1
    Hi Nicola, Thank you for the quick response. I am also using a 47uH inductor from WE similar to the one you have suggested. The following two figures depict my test set-up and PoDL schematic. I am using…
    0 shabaz over 4 years ago
    I don't know the answer but perhaps 20 uH as a minimum is a reasonable first guess start for your tests. It would provide 1k impedance, I don't know if that's enough, but seems a good starting point to me. If the data signal is impacted too much, increase the inductance : )
  • Würth Elektronik
    0 Würth Elektronik over 4 years ago
    Hi suresh11,
    Thank you for you interest in the topic and your question!
    I will be getting in contact with our product manager here and will try to help you with you question as soon as possible.
    Get back to you soon,
    Nicola
    Würth Elektronik
  • Würth Elektronik
    Hi suresh11,
    Hera also a suited appnote for you: https://www.we-online.com/catalog/media/o341320v410%20ANP085b%20EN.pdf
    I hope this helps you. Otherwise please let me know.
    Best regards,
    Nicola
    Würth Elektronik
    • Vote Up +5 Vote Down
  • suresh11
    0 suresh11 over 4 years ago in reply to Würth Elektronik
    Hi Nicola,
    Thank you for the quick response. I am also using a 47uH inductor from WE similar to the one you have suggested. The following two figures depict my test set-up and PoDL schematic. I am using Analog Device EVAL-ADIN1110EBZ board which has 10BASE-T1L (ADIN1110 chip).
    differential mode inductor(L1): WE-744871470
    Transformer: WE-74930120
    Problem:
    The ethernet link is always down (LINK_DOWN) when the device is powered by PoDL. It only works if at the beginning device is powered up from another power source (PoDL is disconnected, at least GND), bring the LINK UP, then switched it to PoDL. It will continue to work until there is no change in the link status i.e. no reset.
    I am having this problem for quite long time. Any kind of help would be appreciated.
    Regards
    Suresh
  • suresh11
    0 suresh11 over 4 years ago in reply to shabaz
    Hi Shabaz,
    Thank you for the response. I am using 47uH inductor. The data signal is not impacted. However, I have a different problem.
    Problem:
    Regards
    Suresh
  • Würth Elektronik
    0 Würth Elektronik over 4 years ago in reply to suresh11
    Hi Suresh,
    to help you could you send us a detailed picture of your construction? Because the Eval board used by you is originally equipped with other components. The best would be a picture from TOP and one from BOTTOM of the board.
    Thank you and best regards,
    Nicola
    Würth Elektronik
  • suresh11
    Hi Nicola,
    I am using this evaluation board from Analog Device.
    I figured out the problem. The problem was the capacitive coupling as Eval-board already has capacitive coupling. I also added them to my prototype.
    Thank you for your help.
    Regards
    Suresh
  • Würth Elektronik
    Hi Suresh,
    I am happy to hear that you figured it out.
    If you need anymore help please let me know.
    Best regards,
    Nicola
    Würth Elektronik
  • zkrough
    0 zkrough over 4 years ago
    Hello suresh, I was wondering how you made out with this design.  I am also working on a project involving SPE and am also trying to implement a PoDL circuit.  I am using the same Dev boards as you, and was wondering if you were able to get it to work.  If so, how did you change your circuit to fix it?  I am having similar issues.
  • zkrough
    0 zkrough over 3 years ago
    Hello suresh11,
    I was wondering how this project worked out for you?  Were you able to connect your below circuit (minus the coupling capacitors) to the development boards and get the PoDL to work?  I had another question, does your Powered Device need to be plugged into your Power Source side upon giving the Power Source side power?  Or can the Power Source side be powered before the Powered Device is attached?  Thank you
