Raspberry Pi
Raspberry Pi
Blog Build a Raspberry Pi media center
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 8 Nov 2012 10:12 PM Date Created
  • Views 3733 views
  • Comments 13 comments
  • raspberry
  • raspi
  • pi
  • video
  • rpibeginner
  • raspberry_pi
  • center
  • media
  • xbmc
e14 Contributor
e14 Contributor
8 Nov 2012
imageWant to build this project?
View Parts
Use your Raspberry Pi as an awesome media portal for listening to music, watching videos, and viewing pictures.
As an old-school XBOX modder, the first thing I wanted to do with my PI was turn it into a media portal. XBMC (Xbox Media Center) is an open source front end for Linux that used to only be available for the Xbox. These days, it is now available for PCs, Linux Distros, Boxee boxes, and most importantly Raspberry Pi.
I used a special Linux distribution built for the Raspberry Pi to build a media center, Raspmc (http://www.raspbmc.com/).
OpenElec is another option (http://wiki.openelec.tv/index.php?title=Building_and_Installing_OpenELEC_for_Raspberry_Pi) .
Setup: Flash Raspmc or OpenElec to an SD Card
Follow instructions on the respective sites to flash a version of XBMC to an SD card. I didn’t have any problems. However, I’d recommended checking searching through forums if anything comes up.  If you are having a problem, it’s possible that someone else has had the same one. Once you’ve flashed XBMC to your SD card, plug it in to the PI and power it up. You now have a Raspberry Pi Media Center.
Notes:
Make sure you have a wired internet connection for the first boot. Raspmc will need it to complete the installation and download updates.
There are some great Android and iPhone apps that you can use to control Raspmc. I use the official XBMC remote App on my iPhone. I also have a retired Droid that I use as a remote also.
There are add-ons for YouTube and other video/music sources. Play around with the options to find the video add-ons you want.
Recommended components:
SD card (4GB or larger)
Micro-usb power supply
Wireless keyword with touchpad
WiFi dongle
USB card adapter
Raspberry Pi enclosure
Powered USB hub
HDMI cable
Additional storage for media (USB flash drive, external hard drive, etc…)
Ethernet cable
Product Name*DescriptionSupplier
Raspberry Pi Model BRaspberry Pi Model BRaspberry Pi model BRaspberry Pi
Buy NowBuy Now
Raspberry Pi Power SupplyRaspberry Pi Power Supply120-240v to 5V power supply with micro USB connectorRaspberry Pi
Buy NowBuy Now
Enclosure for Raspberry PiEnclosure for Raspberry PiClear Plastic enclosure for Raspberry PiMulticomp
Buy NowBuy Now
8GB PNY Class 10 SDHC Card8GB Class 10 high performance SD memory cardPNY
Buy Now
USB 2.0 External Hard DriveUSB 2.0 self-powered external hard drive
Ethernet CableEthernet Cable9.8 ft (3m) category 5e patch cablePro Signal
Buy NowBuy Now
HDMI CableHDMI Cable6.5 ft (2m) male to male standard HDMI cableMolex
Buy NowBuy Now
Wi-PiWi-Pi802.11 b/g/n USB 2.0 Wi-Fi module for Raspberry PiElement 14
Buy NowBuy Now
Mini Wireless USB Keyboard and TrackpadMini Wireless USB Keyboard and TrackpadWireless Mini Keyboard with Trackpad and USB RecieverAdafruit
Buy NowBuy Now
USB 2.0 HubUSB 2.0 Hub7 port self powered USB 2.0 hubAdafruit
Buy NowBuy Now
USB Memory Card Reader56-in-1 USB 2.0 memory card reader / writerIOGear
Buy Now
*Products and resources listed are listed to help members build their own Pi Projects. They are suggestions and listed for educational purposes. For substitutions of any parts, please post a question asking the original author.
    e14 Contributor over 13 years ago in reply to e14 Contributor
    Hi Matt- I haven't played files that large. Let us know if you have any luck.
    Hey Eric,
    I just got my first Pi.  The intention is to use it as a media client to play movies and music from my NAS to my big screen.  I'm concerned that it may not be powerful enough to keep up with 6GB 1080p videos.  So, I bought two, hoping I can combine the two in a HPC cluster.  Any clue how to do that or if it's even possible.  I've heard good things about the performance of the streaming videos, but the best I've seen is a 1.6GB 720p file.  Have you or anyone played a large file of that resolution on a single of these?  Does it work well?
    I have played FLAC file through Raspmc
  • Kuya.Marc
    Kuya.Marc over 13 years ago
    Greetings from The Philippines!
    I've written some articles on running XBMC in the Philippines using Raspberry Pi:
    • Running Raspbmc in The Philippines
    • OpenELEC: Running XBMC on the Raspberry Pi
    Have a nice day, everybody!
    Hi! New to the community and really just starting out so I have a lot to learn.  I think the Raspberry Pi can be used to create a fantastic High Definition Audio Player.  Does the XBMC allow playback of lossless audio formats like WAV and AIFF or to a lesser extent, since they do contain some compression, Apple Lossless or FLAC?
