Raspberry Pi
Raspberry Pi
Blog Build a Raspberry Pi media center
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 8 Nov 2012 10:12 PM Date Created
  • Views 3734 views
  • Comments 13 comments
  • raspberry
  • raspi
  • pi
  • video
  • rpibeginner
  • raspberry_pi
  • center
  • media
  • xbmc
e14 Contributor
e14 Contributor
8 Nov 2012
imageWant to build this project?
View Parts
Use your Raspberry Pi as an awesome media portal for listening to music, watching videos, and viewing pictures.
As an old-school XBOX modder, the first thing I wanted to do with my PI was turn it into a media portal. XBMC (Xbox Media Center) is an open source front end for Linux that used to only be available for the Xbox. These days, it is now available for PCs, Linux Distros, Boxee boxes, and most importantly Raspberry Pi.
I used a special Linux distribution built for the Raspberry Pi to build a media center, Raspmc (http://www.raspbmc.com/).
OpenElec is another option (http://wiki.openelec.tv/index.php?title=Building_and_Installing_OpenELEC_for_Raspberry_Pi) .
Setup: Flash Raspmc or OpenElec to an SD Card
Follow instructions on the respective sites to flash a version of XBMC to an SD card. I didn’t have any problems. However, I’d recommended checking searching through forums if anything comes up.  If you are having a problem, it’s possible that someone else has had the same one. Once you’ve flashed XBMC to your SD card, plug it in to the PI and power it up. You now have a Raspberry Pi Media Center.
Notes:
Make sure you have a wired internet connection for the first boot. Raspmc will need it to complete the installation and download updates.
There are some great Android and iPhone apps that you can use to control Raspmc. I use the official XBMC remote App on my iPhone. I also have a retired Droid that I use as a remote also.
There are add-ons for YouTube and other video/music sources. Play around with the options to find the video add-ons you want.
Recommended components:
SD card (4GB or larger)
Micro-usb power supply
Wireless keyword with touchpad
WiFi dongle
USB card adapter
Raspberry Pi enclosure
Powered USB hub
HDMI cable
Additional storage for media (USB flash drive, external hard drive, etc…)
Ethernet cable
Product Name*DescriptionSupplier
Raspberry Pi Model BRaspberry Pi Model BRaspberry Pi model BRaspberry Pi
Buy NowBuy Now
Raspberry Pi Power SupplyRaspberry Pi Power Supply120-240v to 5V power supply with micro USB connectorRaspberry Pi
Buy NowBuy Now
Enclosure for Raspberry PiEnclosure for Raspberry PiClear Plastic enclosure for Raspberry PiMulticomp
Buy NowBuy Now
8GB PNY Class 10 SDHC Card8GB Class 10 high performance SD memory cardPNY
Buy Now
USB 2.0 External Hard DriveUSB 2.0 self-powered external hard drive
Ethernet CableEthernet Cable9.8 ft (3m) category 5e patch cablePro Signal
Buy NowBuy Now
HDMI CableHDMI Cable6.5 ft (2m) male to male standard HDMI cableMolex
Buy NowBuy Now
Wi-PiWi-Pi802.11 b/g/n USB 2.0 Wi-Fi module for Raspberry PiElement 14
Buy NowBuy Now
Mini Wireless USB Keyboard and TrackpadMini Wireless USB Keyboard and TrackpadWireless Mini Keyboard with Trackpad and USB RecieverAdafruit
Buy NowBuy Now
USB 2.0 HubUSB 2.0 Hub7 port self powered USB 2.0 hubAdafruit
Buy NowBuy Now
USB Memory Card Reader56-in-1 USB 2.0 memory card reader / writerIOGear
Buy Now
*Products and resources listed are listed to help members build their own Pi Projects. They are suggestions and listed for educational purposes. For substitutions of any parts, please post a question asking the original author.
  • fustini
    fustini over 13 years ago in reply to Montirosso
    Raspbmc has CEC which should allow you to control XBMC with your TV remote (if the Pi is connected to your TV via HDMI).
    http://www.raspbmc.com/2012/11/new-with-raspbmc/
    "CEC support updated: CEC support has been updated yet again, this time to version 2.0.4. This brings improvements to LG and Panasonic TVs"
    Here's a video of using CEC with the Pi:
    http://www.youtube.com/watch?v=XPyOyJsnB1o&feature=player_embedded
    I just started playing around with Airplay from my iPhone. It's working out pretty seemlessly. I'm enjoying it a little more than accessing the scanned music library through the xbmc remote app.
    -Eric
  • Montirosso
    Montirosso over 13 years ago
    With my LG television it is even possible to control the PI with XMCB with the television's remote
    e14 Contributor over 13 years ago in reply to e14 Contributor
    Hello Eric,
    Great many thanks! Looks like I have a project for the coming holiday season...
    Rgds,
    Ernest
    Hi Ernest,
    If I understand your question correctly, I think Raspberry Pi can accomplish what you are trying to do. I have actually been using it this way myself.
    If you are using your phone as a remote, you don't need to have the TV powered on. You could connect your Raspberry Pi directly to the stereo. The remote apps will allow you to sort through and play music through the Raspberry Pi from your phone.
    No coding necessary! (I'm not a developer either)
    -Eric
