Raspberry Pi
Raspberry Pi
Blog C++ gpio library for Raspberry Pi - Pt 3: Blinky!
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 7 Jan 2024 2:44 PM Date Created
  • Views 3745 views
  • raspberrypi
  • raspberry-pi-projects
  • c++
7 Jan 2024
An exercise to build a C++ library for the GPIO pins. The programmer can decide what underlying mechanism is used to talk to the pins. In this 3rd post, finally, a Blinky!
#include "memmapdevice.h"
typedef dgpio::pin<dgpio::memmapdevice> pin;
pin p = pin(21);
pin.init(pin::dir::out);
while(true) {
  p.set(p.get() == pin::status::off ? pin::status::on : pin::status::off);
  usleep(1000000)
Example program
What happended before?
C++ gpio library for Raspberry Pi - Pt 1: Design and How To Use
C++ gpio library for Raspberry Pi - Pt 2: Plug In drivers for direct register GPIO, or file system based GPIO
I created a C++ library for the Pi. With a very simple API: A single class pin. With (de)initialisation functions, and a getter + setter. But: can it blink?
The answer is yes. Here is example code:
#include "pin.h"
#include <stdlib.h> // atoi
#include <unistd.h> // usleep
int main(int argc, char *const *argv) {
	pin p = pin(21);
	p.init(pin::dir::out, pin::status::off);
	while(true) {
		usleep(1000000);
	p.deinit();
Want to try it yourself? You can help me to improve instructions, by trying it out. See the readme.
github repo: https://github.com/jancumps/cppgpio
    shabaz over 2 years ago
    Although I still need to set it up, I will use this library to control my LoRaWAN gateway status light (to indicate whenever LoRaWAN traffic occurs for my devices!).
