Raspberry Pi
Raspberry Pi
Blog Cheap portable LCD for Raspberry Pi
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: fustini
  • Date Created: 4 Jul 2012 6:36 AM Date Created
  • Views 5846 views
  • Comments 25 comments
  • raspberry_pi
fustini
fustini
4 Jul 2012
I've been wanting a small portable display for the Pi.  Unfortunately, portable HDMI displays are quite expensive, and the DSI connector is not an option currently as far as I know.  Then I realized that there a large number of small composite LCDs available which are intended for use in vehicles for backup rearview cameras.  I bought this inexpensive LCD on Amazon, the 3.5 Inch TFT LCD Monitor for Car / Automobile by kingsmart for $21.48 (my order was sold by ePathDirect and fulfilled by Amazon):
It arrived today, and I put the photos I took in a Picasa gallery.  I hooked it up to my bench power supply and simply connected it's yellow connector to the composite output on the Pi.  The monitor displayed the Pi's ouptut ok right at power on, through the boot process and beyond.  As I expected, the resolution is poor, especially for small text, given it is standard definition and connected with composite.  However, I'm intending to use this monitor to display tweets, so I can increase the font size as tweets are only 140 characters.  I think this monitor will also be handy for basic troubleshooting when ssh or serial won't suffice, and I don't want to bother with a regular sized monitor.
Anyone have any other ideas for inexpensive displays?
Cheers,
Drew
  • sknipas
    sknipas over 14 years ago +1
    I have a 9 inch monitor from an old mini laptop. I also bought a lvds controler from e-bay and I am planning to use this monitor and the r-pi as a car pc. Screen resolution goes up to 1024x600.
    e14 Contributor over 14 years ago in reply to fustini +1
    It works quite well... But there are some minor disadvantages... 1. you have to concentrate your eyes to have the two displays properly over each other so you have a single image 2. the border region is…
  • jeffbiss
    jeffbiss over 13 years ago in reply to fustini +1
    Now that you mention it, I did the same thing and plumb forgot about it because the screen came with no information! The LCD uses about 5 VDC and has a regulator internally that reduces the car's 12 VDC…
  • fustini
    fustini over 13 years ago in reply to e14 Contributor
    Hi - I used 2.1mm jack to screw terminal adapter from Adafruit:
    https://www.adafruit.com/products/369
    There's a pic of it in this post:
    http://www.element14.com/community/groups/raspberry-pi/blog/2012/09
    e14 Contributor over 13 years ago in reply to jeffbiss
    It's the very same monitor as the original post, the one in the images, the power cable that came with it is just a cable with a red and black wire sticking out the end of it
  • jeffbiss
    jeffbiss over 13 years ago in reply to e14 Contributor
    What monitor? The monitor should have come with some sort of wiring diagram. Did you try the manufacturer's site?
    Hi I was wondering how you connected up the power supply to the monitor? mine arrived today but I have no idea how to wire this thing up, I want to connect it to a standard power supply, how can I do this?
    e14 Contributor over 13 years ago in reply to e14 Contributor
    On the Ipad I use the Mocha VNC Lite.  On the Pi I run the TightVNC server as described here: http://www.cnx-software.com/2012/04/19/how-to-setup-a-vnc-remote-connection-to-a-raspberry-pi/ .
