    • Avnet Boards Community
Raspberry Pi
Raspberry Pi
Blog External Antenna for Raspberry Pi 4
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: aswinvenu
  • Date Created: 22 Sep 2024 2:56 PM Date Created
  • Views 12703 views
  • Likes 10 likes
  • Comments 13 comments
  • raspberry pi 4
aswinvenu
aswinvenu
22 Sep 2024
     For one of the Raspberry Pi projects I have been working on had this specific requirement for an external antenna. The entire Raspberry Pi 4 needs to be placed inside a metal box. So external antenna was the only option left for me to make the Bluetooth and WiFi to work. I had two choices, One to use the compute module 4 and use the IO board or use a regular RPi and somehow add a UFL/IPEX Connector to the PCB. Considering the cost and availability I preferred to try the second option.
    On a closer inspection of the WiFi/BLE Module area, We can see a small provision where a UFL/IPEX Connector can fit. Ofcourse there are no expose pads for an UFL/IPEX connector. We need to create one ( Atleast the ground pads ).
Step 1
  Remove the solder mask and prepare a nice and clean exposed copper pad for soldering the UFL/IPEX connector.
Step 2
    Cut the trace which goes to the on PCB Antenna and solder a 0201 0E resistor like shown below.
Step 3
   Remove the capacitors used in the PCB Antenna.
Done! I connected an IPEX 4dB antenna to the my RPi 4 for a quick test.
Result
Everything works fine and I am getting roughly 4- 5dB difference compared to the stock PCB antenna.
My router was atleast 5-6 meters away from the RPi and there was a wall separation.
    shabaz over 1 year ago in reply to aswinvenu +2
    That's slightly different, that's unwanted emissions (but also relevant for products for sure). Every country has a regulatory body for wireless, e.g. in the USA it is FCC, and in the UK it is Ofcom (those…
  • zip00
    zip00 7 months ago
    What about mounting a diversity between the two traces? Is that possible?
  • zip00
    zip00 7 months ago
