Raspberry Pi
Raspberry Pi
Blog Introducing the NEW Raspberry Pi Compute Module
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: lbittner
  • Date Created: 7 Apr 2014 11:59 AM Date Created
  • Views 10257 views
  • Comments 25 comments
  • raspberry
  • applications
  • raspberry_pi_compute_module_development_kit
  • industrial
  • pi
  • compute
  • embedded
  • raspberry_pi
  • io_board
  • raspberry-pi
  • development
  • kit
  • design-in
  • module
lbittner
lbittner
7 Apr 2014
Designing in the Future: Raspberry Pi Compute Module Development Kit
Coming Summer 2014!
The new Raspberry Pi Compute Development Kit enables design engineers
to harness the power of the Raspberry Pi for embedded applications.
  • Small and Powerful. SODIMM sized (6.5cm by 3cm) Raspberry Pi board contains the BCM2835 chip with 512MB RAM with an on board 4GB eMMC Flash memory for booting the OS.
  • Flexible and Rapid Prototype Development. A fully functional IO board is part of the development kit which supports an extensive GPIO and multiple connectors to help foster rapid prototype development with access to all of the BCM2835 functionality.
  • Custom Hardware and Software Solutions. Benefit from fully functional Linux server running on your ‘design-in’ hardware solution. This unique combination of services will help define the next generation of the ‘Internet of Things’
Compute Module Development Kit Technical Specifications:
Compute Module:
  • SODIMM sized 6.5cm by 3cm board
  • BCM2835 chip with 512MB RAM
  • On board 4GB eMMC Flash memor
  • 200 pin edge connector
IO board:
  • Multiple GPIO interfaces
  • 1 x micro USB connector type B
  • 1 x USB connector type A
  • 2 x CSI ports for camera boards
  • 2 x DSI ports for display boards
  • Full size HDMI port
Harness the power of the Raspberry Pi for your embedded applications!
Request Consultation...
Complete this form and one of our Design Representatives will call you to discuss your embedded design.
See schematics for:
Compute Module
Io Board
  • raspberrystore
    raspberrystore over 12 years ago in reply to e14 Contributor +2
    Its just who develops an IO-board first, with only ethernet, GPIO (USB?) and power (on the same side). Sadly not me, Id really like to test them!
  • lbittner
    lbittner over 12 years ago in reply to jamodio +1
    Thanks for alerting us, jamodio! The two links will now take you and other members to separate documents. Best, Lauren
    e14 Contributor over 12 years ago +1
    Ethernet port?
    Ethernet port?
  • lbittner
    Best,
    Lauren
  • jamodio
    jamodio over 12 years ago
    Also, it seems that both links for the schematics above takes you to the same file, which is the schematics for the Compute module.
    BTW, good first step forward about releasing the schematics in advance.
    -J
    Ditto
  • jamodio
    When we can pre-order it ?
    Thanks
    Jorge
