Raspberry Pi
Raspberry Pi
Blog Pi will not boot up.
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: chiversj
  • Date Created: 5 Jun 2012 6:55 PM Date Created
  • Views 1697 views
  • Comments 8 comments
chiversj
chiversj
5 Jun 2012
I turned on my unit just now for the first time and I can not get it to work. I have 4.8 volts on the unit and the red led is lit. The green led does NOT flash. I am using an SD card from Wal Mart. I downloaded Debian. The SD card shows it has two files on it. One large and one small. Any help would be appreciated. jimmy
    e14 Contributor over 14 years ago in reply to e14 Contributor
    Dear William and others
    Thanks for the advice
    I am pleased to say that my boot problem has been solved by changing to the Wheeze Beta version of the operating system
    When I had the problem I was using the "official" squeeze version of the debian OS
    So my suggestion to anyone with a boot problem where boot does start but will not complete is to try the Wheeze Beta version of the OS
    For the record my SD card is an 8GB SANDISK bought from Element14
    I am using a small Cherry keyboard G84-4100
    A Lenovo optical mouse
    A PSU from Maplin
    And a HDMI to DVI adapter into an NEC monitor
    Regards Donald  (DeeKay)
    Erm...
    What OS are you using?
    Thanks
    Will950
    If my advise has helped anyone please Reply to the message because a friend is asking me the same question and i don't whether to give him the same advise!
    Thanks
    will950
    The most likely cause of these problems is a incompatible SD Card. There is considerable talk on this topic on the Raspberry Pi forum at raspberrypi.org. Not all SD Cards are the same unfortunately.
    I have a Kingston 2GB card that doesn't work, and a no name MicroSD card that does. It is a bit pot-luck I'm afraid.
    Can you help
    My Raspberry PI does start the boot sequence
    Power red light is bright, OK LED flashes green during boot up
    Boot sequence seems to recognise keyboard and optical USB Mouse
    Key presses appear on screen
    Eventually boot up sequence gets to the following message
    mmc0:  Timeout waiting for hardware interrupt
    This message keeps on repeating in a wait for ever loop
    Any ideas
    DeeKay
