Raspberry Pi
Raspberry Pi
Blog Raspberry Pi Operating Temperature Comparison (A+, B+, Zero, Pi 2, Pi 3)
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: cstanton
  • Date Created: 2 Mar 2016 12:57 PM Date Created
  • Views 9349 views
  • Likes 10 likes
  • Comments 20 comments
  • b+
  • heat
  • raspberry pi 2
  • raspberry pi operating temperature
  • a+
  • raspberry pi
  • model a+
  • model b+
  • raspberry pi heat
  • raspberry pi 3
  • model b
  • raspberry pi 1
  • raspberry pi temperature
cstanton
cstanton
2 Mar 2016
Thanks to Gareth Halfacree, whom took a series of photographs of the Raspberry Pi processor under heavy load, I think. Note there's no load on the GPU in these photographs. You can see how potentially hot each processor chip of the Raspberry Pi get. These are at stock processing speeds with no overclock and using sysbench to push the CPU.
element14 does sell Raspberry Pi HeatsinksRaspberry Pi Heatsinks
{gallery} Raspberry Pi Operating Temperatures Individual Scaling
Raspberry Pi 1 Model A+: 13.5degC to 28.8degC
Raspberry Pi Zero: 13.1degC to 44.1degC
Raspberry Pi 1 Model B+: 14.9degC to 32.5degC
Raspberry Pi 2 Model B: 12.4degC to 49.4degC
Raspberry Pi 3 Model B: 16degC to 87.6degC
Raspberry Pi 3 Model B Close up: 45.1degC to 101.3degC
{gallery} Raspberry Pi Operating Temperatures Normalised Scale
Raspberry Pi 1 Model A+: Normalised Temperature View
Raspberry Pi Zero: Normalised Temperature View
Raspberry Pi 1 Model B+: Normalised Temperature View
Raspberry Pi 2 Model B: Normalised Temperature View
Raspberry Pi 3 Model B: Normalised Temperature View
    shabaz over 10 years ago in reply to clem57 +3
    Hi Clem, It will be guesswork, because not all characteristics are know, but this online tool is useful: Calculating heat sinks Usually I plug in approximate values if they are not known (there are some…
  • bwelsby
    bwelsby over 10 years ago in reply to cstanton +2
    Christopher Stanton wrote: HAT add on boards will likely also be affected due to vertical clearance, or lack of. yes that's a problem, maybe something like this is better : MPC151525T - AMEC THERMASOL…
    shabaz over 10 years ago in reply to bwelsby +2
    That's actually really good. Those ceramic heatsinks are (literally) cool : ) I actually have one here for another project, but unfortunately 22x22mm : ( will see if it fits. ( MPC222225T - AMEC THERMASOL…
  • cstanton
    cstanton over 10 years ago in reply to Robert Peter Oakes
    Ha ha ha, 12degC is actually the lowest temperature allowed by health and safety for working conditions in the UK image
  • clem57
    clem57 over 10 years ago in reply to Robert Peter Oakes
    Or they are located in Antarctica. LMAO
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago
    Hi Chris
    Where are these being tested.... 12 Deg for the low, either someone is being a scrooge and not heating the workplace in winter or these are right out of the fridge image
    Hi Clem,
    Usually I plug in approximate values if they are not known (there are some example thermal resistances given, but not for BGA,
    so I just looked at a random BGA product datasheet, although the one I looked at was not 14x14mm, but was slightly larger : (
    Basically we keep hitting the issue of lack of datasheets / user manuals for the BCM chip : (
    I don't have a tool to measure (I could try a thermocouple or the low-res home-made thermal array cam), but might end up relying
    on the temperature reported by the chip for now. Still need to download and get the image onto the microSD..
  • clem57
    clem57 over 10 years ago in reply to bwelsby
    Any guess of how well (specific cooling maybe) this should work?
    Clem
