Raspberry Pi
Raspberry Pi
Blog Raspberry PIO Stepper Library: Trying it out with a Pi Pico and two Stepper Motors!
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: shabaz
  • Date Created: 23 Apr 2025 7:13 PM Date Created
  • Views 5225 views
  • Likes 9 likes
  • Comments 14 comments
  • raspberry
  • pico
  • PIO
  • stepper-motor
  • c++
shabaz
shabaz
23 Apr 2025
Stepper motors are super-useful for precision movements.
I made a little stepper motor board a while back, but never got around to testing it at the time.
Jan Jan Cumps has created a stepper motor control library (click here to learn about it:  Raspberry PIO stepper library documentation - 1: intro, set up project and simple example )  that uses special hardware inside the Pi Pico chip, called PIO. The PIO hardware allows for precise control of inputs and outputs.
The PIO is used to pulse an output that goes to a Toshiba chip which translates that to higher-current outputs in a sequence to drive the coils of the motor.
The video shows a quick first test of the board, using Jan's stepper motor library.
Here's another short video; showing interaction from a terminal/console connection. This will be useful when trying out new stepper motors and mechanisms, to experiment and discover what speeds and steps are needed:
The stepper motors/leadscrew/linear rails combo were purchased from AliExpress quite a while ago. The particular AliExpress seller no longer has more to sell, but I have seen that other AliExpress sellers have very similar-looking options.
I need to experiment a bit more, but it's great to see the board operational with the stepper motor code.
The circuit diagram is below (this is a more recent revision 1.1, compared to the revision 1.0 board which I used. The rev 1.1 board is directly compatible with Jan's stepper motor library, whereas the older rev 1.0 board needs a few resistor changes). The PDF circuit diagram is downloadable here.
If you wish to build the board, see the pico-dual-stepper GitHub repo for the Gerber files.
Top layer:
3D render:
The underside doesn't have any components:
The PDF Parts List is available here.
  • BigG
    BigG over 1 year ago in reply to Jan Cumps
    docs.python.org/.../asyncio.html
    Jan Cumps over 1 year ago in reply to BigG
    the interrupt that I'm generating (and will have to try and capture) isn't one based on a pin's edge. It should fire when all steps are generated - a logic-condition-based interrupt cause.
  • BigG
    I thought as much. Cool.
    I believe the pigpio python library for raspberry pi allows you to use hardware interrupts. There's also an updated/enhanced RPI.GPIO library out there that does the same (cannot remember exactly which one).
    import pigpio
    import time
    def my_callback(gpio, level, tick):
        print(f"Interrupt on GPIO {gpio}, level {level} at tick {tick}")
    pi = pigpio.pi()
    if not pi.connected:
        exit()
    gpio_pin = 4  # Example GPIO pin
    pi.set_mode(gpio_pin, pigpio.INPUT)
    pi.set_pull_up_down(gpio_pin, pigpio.PUD_DOWN) # Or PUD_UP
    # Trigger callback on rising edge
    pi.callback(gpio_pin, pigpio.RISING_EDGE, my_callback)
    try:
        while True:
            time.sleep(1)
    except KeyboardInterrupt:
        pi.stop()
    shabaz over 1 year ago in reply to shabaz
    Done, it is here:
    https://github.com/shabaz123/pico-dual-stepper/tree/main/interactive_console_example/stepper_test2
    Added an interactive console thing to quickly test out things on-the-fly (it's now embedded in the main blog too):
    https://youtu.be/SxN2Bi1Z2GM
    I'll put the code at the same GitHub location hopefully tonight or tomorrow.
