Raspberry Pi
Raspberry Pi
Blog Stepper Motor Control with Raspberry Pico PIO and DRV8711 driver- Part 3: GPIO
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 3 Apr 2025 6:37 PM Date Created
  • Views 1515 views
  • Comments 8 comments
  • pico
  • pico_eurocard
  • PIO
3 Apr 2025
The Pico has a set of PIO co-processors. They are real-time controllers that can execute logic with deterministic timing. Ideal to run strict-timed sequences and state machines. And to implement extra peripherals.
In this series, I'm trying to use the PIO to control a TI DRV8711 stepper motor controller.
Follow up of  Stepper Motor Control with Raspberry Pico PIO and DRV8711 driver- Part 2: SPI .
Next to power, the driver IC has some digital inputs that we need to entertain. This post is my doco on how I connected them. Very short, nothing real happening here.
These are the Pico resources I reserve:
signal DRV8711 Pico
direction DIR
IO4
step STEP
IO5
sleep SLEEP
IO14
reset nRESET
IO15
power
3V3
ground
GND
All are outputs, Here's the code to set them. And a little helper.
#define NSTALL (-1)
#define NFAULT (-1)
#define NSLEEP (14)
#define RESET (15)
#define DIR (4)
#define STEP (5)
void init_drv8711_hw() {
    // nStall and nFault as input
    // not used
    // gpio_init(NSTALL);
    // gpio_set_dir(NSTALL, GPIO_IN);
    // gpio_set_pulls(NSTALL, true, false); // drv8711 outputs are open drain
    // gpio_init(NFAULT);
    // gpio_set_dir(NFAULT, GPIO_IN);
    // gpio_set_pulls(NFAULT, true, false); // drv8711 outputs are open drain
    // nSleep and Reset as output
    gpio_init(NSLEEP);
    gpio_put(NSLEEP, 0);
    gpio_set_dir(NSLEEP, GPIO_OUT);
    gpio_init(RESET);
    gpio_put(RESET, 0);
    gpio_set_dir(RESET, GPIO_OUT);
    // bin1 and bin2 as output
    // not used
    // DIR and STEP as output
    gpio_init(DIR);
    gpio_put(DIR, 0);
    gpio_set_dir(DIR, GPIO_OUT);
    gpio_init(STEP);
    gpio_put(STEP, 0);
    gpio_set_dir(STEP, GPIO_OUT);
void sleep(bool yes) {
    gpio_put(NSLEEP, yes? 0 : 1);
In main(), the pins are set. Before the logic, the driver is is woken up. At that time, a blocking current flows, that holds the motor in place.
When all done, we release that motor lock and send the driver to sleep again:
int main() {
    init_drv8711_hw();
   sleep(false);
   // business ...
   sleep(true);
    return 0;
Next post: PIO and putting it all together.
Thank you for reading.
    Jan Cumps over 1 year ago
    Jan Cumps over 1 year ago in reply to DAB
    next post is about the Pico PIO controllers. A bit more involved.
    Luckily, it's a simple example: creating a pulse train with count x.
    DAB over 1 year ago
    Nice and simple.
