Raspberry Pi
Raspberry Pi
Blog Win a Raspberry Pi 5 from the element14 Community!
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: e14phil
  • Date Created: 28 Sep 2023 6:24 AM Date Created
  • Views 25584 views
  • Likes 17 likes
  • Comments 251 comments
  • competition
  • raspberry pi 5
  • raspberry pi 5 giveaway
  • win a raspberry pi 5
e14phil
e14phil
28 Sep 2023
Win a Raspberry Pi 5!
We have just announced the release of the amazing Raspberry Pi 5, with its 2.4GHz quad-core, 64-bit Arm Cortex-A76 CPU, VideoCore VII GPU, LPDDR4X-4267 SDRAM (4GB and 8GB SKUs available at launch), 2.4 GHz and 5.0 GHz 802.11ac Wi-Fi, and Bluetooth 5.0 / Bluetooth Low Energy (BLE).
This Competition is now Closed.
Congratulations JWx our team has selected you as the winner of our Raspberry Pi 5 Give away!
We hope to see your experiments with the PCI-E functionality.
/products/raspberry-pi/b/blog/posts/win-a-raspberry-pi-5-from-element14-community?CommentId=0f1e6de3-ee46-457b-bc91-71acc33df059
Check out our Raspberry Pi 5 announcement blog here:
 Introducing The New Raspberry Pi 5 - 3x Faster, 2.4GHz, VideoCore VII GPU, RTC, Gigabit Ethernet, 1GB, 2GB, 4GB, 8GB RAM
If you would like to win a Raspberry Pi 5, all we want to know is ... "What would you build with a Raspberry Pi 5?"
How to Enter:
Comment on this blog below, answering the question: What ould you build with a Raspberry Pi 5? We will send our favorite commenter a Raspberry Pi 5.
End Date: 30th November 2023 at 23:59
Click here for Terms & Conditions.
Note: When selecting winners, if we discover that your name and address details are not correct on your Community account profile, we will choose a different winner.
Make sure your profile information is correct and up to date.
  • misaz
    misaz over 3 years ago +4
    In last years I used most time used Raspberry Pi for some kind of long-term automation. For example, last few months two of my Raspberry Pies was running experiments (one Rpi 4B and one 3B+) to evaluate…
  • ItsZephyrOne
    ItsZephyrOne over 3 years ago +3
    I already have a Raspberry Pi Zero; I tried desktop on it, but Zero doesn't have processing power, which is why I need a Raspberry Pi 5.
  • draq357
    draq357 over 3 years ago +3
    I would probably set this up as a server to receive weather information, and display it on a smart mirror. It would get weather info from the home built station in my backyard.
  • corbo
    corbo over 3 years ago
    I would use it to build an all in one monitoring and door control system for my chicken coop.  One camera inside, one pointed outside.  Motor control to wind up the door.  It would be great!
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago
    I would build a NAS drive with connection to an off-site backup storage. Because backups are useless if they are in the same place as the original data.
  • Shashwat1
    Shashwat1 over 3 years ago
    I will update my garden care and monitoring system using RP5
  • Hazzerath
    Hazzerath over 3 years ago
    I'd refresh my home automation. Likely get a NVME drive to store data.
    With the additional power i could run more docker containers and run more home services and some machine learning workflows.
    I also have a speaker kit I'd probably modify that to give it some audio though USB
  • hackerneo
    hackerneo over 3 years ago
    Setup a k8s single node cluster, untaint the master to allow pods to run, run koperator (Kafka operator), redis and ML pods, enable ingress, deploy kong API gateway and a react UI pod and deploy opa gatekeeper to enable ztna for inter microservice calls, with a minimal load and then scale to 3 mode cluster for developing an end-to-end distributed system
