Raspberry Pi Forum Adafruit's Raspberry Pi Kernel-o-Matic
  • Subscribers 705 subscribers
  • Views 546 views
  • rpi
  • kernel
  • adafruit
  • linux
fustini
fustini over 10 years ago
I just came across this today.  Aside from the awesome cartoon, it strikes me as an easy way to create custom Linux kernels:
https://github.com/adafruit/Adafruit-Pi-Kernel-o-Matic
A detailed guide for using the Kernel-o-Matic can be found on The Adafruit Learning System. If you are familiar with Vagrant and VirtualBox, a brief overview of the build process can be found below.
cheers,
drew
(@pdp7)
    shabaz over 10 years ago
    Hi Drew,
    It looks nice! It makes sense, having a defined VM that can be used for builds, and if Vagrant provides that (I've not heard of it before) then this is awesome - makes life so much easier when people are working with known environments. Thanks for sharing it, it looks very interesting.
    In a similar vein, I've sometimes wished that tools vendors would also provide a VM download option. In other words use the tools as an appliance sitting anywhere e.g. network storage, and run it with whatever resources I want.
  • Problemchild
    Problemchild over 10 years ago in reply to shabaz
    Vagrant  provides a mechanism to build and configure VMs. Which is really an additional step over having a machine pre -configured.
    However it does lead you down a path of further abstraction. Either way a separate VM committed to a particular cross-compiled environment means that you have an environment that works and also doesn't break your main host ...much nicer
