Raspberry Pi Forum Wireless network conectivity
  • Replies 75 replies
  • Subscribers 707 subscribers
  • Views 10176 views
  • raspberry
  • pi
  • wireless
wallarug
wallarug over 14 years ago
I bought one of these about 12 mths ago: http://www.jaycar.com.au/productView.asp?ID=YN8306&keywords=high+power+wireless+n&form=KEYWORD
I downloaded the drivers from the link above then installed them on a windows computer.  How do I use these linux drivers/installers on the raspberry pi to get the wireless adaptor to work?
Will this work with the Raspberry Pi?
  • rew
    rew over 14 years ago in reply to wallarug
    maybe
      sudo apt-get install iw
  • wallarug
    wallarug over 14 years ago in reply to wallarug
    http://wiki.debian.org/rt2800usb
    This looks hopeful (but it is for the Wheezy Debian not Squeeze, does that matter?)
  • wallarug
    wallarug over 14 years ago in reply to rew
    Roger Wolff wrote:
    maybe
    Seems to have worked.  I will try the other commands and see if that has fixed other problems.
  • wallarug
    Also ( as a side question):
    How do you create a shortcut to a folder in linux to a networked share drive?
    I know how to connect to it by typing
    smb: <location>
    But how do you create a shortcut?
  • wallarug
    Progress made:  The Wlan adapter has power (which it didn't before) but the RPi is playing up, The RPi does not like the iwconfig command.  Any thoughts?
  • wallarug
    I got this error:
    wpasupplicant deamon failed to start
    Which means I have an error in the:
    /etc/wpa.conf
    ...file.
    But I don't know where they are.  I can tell you that I have a WPA+WPA2 sercurity setting active on the router but I don't know how that information translates into the /etc/wpa.conf file.
    This is what I curently have: (minus the ssid and password image - security purposes image)
    network={
    ssid="network2.4"
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=CCMP TKIP
    group=CCMP TKIP
    psk="passwordisfake"
    Can anyone help me get the correct information into that file???
    EDIT: Just found an error but that has not fixed the problem.
  • wallarug
    I am reading this article: https://wiki.archlinux.org/index.php/WPA_supplicant
    Do I need to do anything relating to WPA_supplicant  or not?
    This looks like it could work and if it does then the wiki should add this.  I will play around with this tomorrow.
  • rew
    Hmmmm. It seems I missed one of your posts....
    WPA supplicant does something relating to WPA. So if your wifi is WPA protected, your 'pi will have to do something with WPA_SUPPLICANT. Whether or not this is hidden "behind  the scenes" I don't know.
    On my Ubuntu Laptop, I have this fancy network-icon in the toolbar. It shows the wifi networks, and when I select an encrypted one, it asks me for the password. From then on it connects automatically....
    That applet is called "nm-applet".
    I'm usually a commandline guy, but with wifi, I kind of like the fact that I haven't had to delve into it to have it work.
    Hmm. come to think of it, I have my home-pi on my (encrypted) home network. I just have
    auto wlan0
    iface wlan0 inet dhcp
    wpa-conf /etc/wpa.conf
    in /etc/network/interfaces and then
    network={
    ssid="XXXXXX"
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=CCMP TKIP
    group=CCMP TKIP
    psk="XXXXXXX"
    in /etc/wpa.conf .
    Then a restart of the network should work. Again I'm lazy figuring out how to do that, so I either unplug/replug the wifi dongle, or I just reboot the whole thing. (I'm sure it can be done, but not doing it is faster).
  • wallarug
    I will look into WPA supplicant.  For my RPi and network.  The link above seemed to look good and easy to do.,
  • wallarug
    Have not had time to look into WPA supplicant stuff.  but now that I know the model of the wireless adapter (RT2870) I can put the supplied drivers up here.  I hope that someone can tell me what to do with what was given to me and whether or not I need to install/add anything to the Raspberry Pi for wireless adapter to work.
