Raspberry Pi Forum Wireless network conectivity
  • Replies 75 replies
  • Subscribers 707 subscribers
  • Views 10188 views
  • raspberry
  • pi
  • wireless
wallarug
wallarug over 14 years ago
I bought one of these about 12 mths ago: http://www.jaycar.com.au/productView.asp?ID=YN8306&keywords=high+power+wireless+n&form=KEYWORD
I downloaded the drivers from the link above then installed them on a windows computer.  How do I use these linux drivers/installers on the raspberry pi to get the wireless adaptor to work?
Will this work with the Raspberry Pi?
    e14 Contributor over 14 years ago in reply to wallarug
    http://wiki.debian.org/rt2870sta#Installation
    i simply followed that for installing my RT2800 series wireless dongle, worked first time.
    so, simpllified these are the steps i took.
    sudo apt-get install firmware-ralink
    sudo apt-get install network-manager-gnome
    sudo reboot
    when rebooted, log in, startx and find the network manager in the bottom right corner, select your connection, put password in and it should all work.
    you can of course mess with the /etc/network/interfaces to enable network at boot.
    hope this helps somewhat...good luck
    EDITED TO REMOVE INCORRECT LINK
  • wallarug
    wallarug over 14 years ago in reply to e14 Contributor
    Trying this now.
  • wallarug
    network manager seems to be slowing down the RPi quite alot.  I am having speed issues with this program.  Also, it installed a bluetooth process which I don't need, how do I kill that process?  (I tried "ps-l" but it does not come up but it does with "pstree")
    EDIT: so that it will not start ever-again.
    you can remove the network manager if you want (sudo apt-get remove network-manager-gnome) and edit the /etc/network/interfaces file so it connects at boot (sudo nano /etc/network/interfaces)
    this is how mine looks:-
    auto lo
    iface lo inet loopback
    auto wlan0
    iface wlan0 inet static
    address 192.168.0.50 (for example)
    netmask 255.255.255.0 (for example)
    gateway 192.168.0.1 (for expample)
    wireless-essid wireless network name here
    wireless-key wireless password here
    iface eth0 inet dhep
    cant help with killing the bluetooth process (sorry).
  • wallarug
    How come what you have in that file is different to what the wiki says to input?
    Also, do you know if I have to change anything (from the above) if I use WPA2 security?
    I am also going to use a fresh image (Debian Wheezy) when I find time to set it up.
    i cant find where i got that info from, i will keep looking but in the mean time you can have a look at the following
    http://wiki.debian.org/WiFi/AdHoc
  • wallarug
    I see.
    You have an ADhoc network set-up.
    I want to use a different set-up involving existing network equipment.
  • wallarug
    what image are you using?
  • wallarug
    auto lo
    auto wlan0
    I got it, the bluetooth process (and many more) have been removed with the command: apt-get autoremove
    Hope I haven't done too much damage. image
    i am using the squeeze image from R-Pi.org, tried wheezy but it gave me some problems.
