Raspberry Pi Forum Wireless network conectivity
  • Replies 75 replies
  • Subscribers 707 subscribers
  • Views 10210 views
  • raspberry
  • pi
  • wireless
wallarug
wallarug over 14 years ago
I bought one of these about 12 mths ago: http://www.jaycar.com.au/productView.asp?ID=YN8306&keywords=high+power+wireless+n&form=KEYWORD
I downloaded the drivers from the link above then installed them on a windows computer.  How do I use these linux drivers/installers on the raspberry pi to get the wireless adaptor to work?
Will this work with the Raspberry Pi?
  • wallarug
    wallarug over 14 years ago in reply to wallarug
    Found this: http://forums.whirlpool.net.au/archive/1439103 but I don't know where the: "Linux kernel source code header files are installed "
    Could someone please fill in the blanks from this post.  Which include: steps 2 and 3.
    This would be much appreciated.
    Thanks in advanced.
  • GreenYamo
    GreenYamo over 14 years ago in reply to wallarug
    Hello Fergus,
    Are you sure that it is a 2770 ? Looking at the smaller chip, it is a 2720 which brings up a lot more hits for me in Google regarding wireless cards.
    I'm afraid I am not much of a Linux expert, but what you are posting above looks like you are compiling from source which is well above my head, perhaps someone else could comment on that.
    Have a look at the following link, that may be some help: http://wiki.debian.org/rt2870sta
    I know this may sound a little defeatist, and i'm happy to be told so, but at some point I would say you need to cut your losses and possibly think about buying a USB adaptor that is known to work with the Pi, rather than spending so much time trying to get your current one working ?
    Steve
  • wallarug
    wallarug over 14 years ago in reply to GreenYamo
    I think I will take your advice:
    "      but at some point I would say you need to cut your losses and possibly think about buying a USB adaptor that is known to work with the Pi, rather  than spending so much time trying to get your current one working ?"
    What do you think of this one: http://www.jaycar.com.au/productView.asp?ID=YN8309
    Although it is not branded on the Jaycar website, I think that it is the EW-7811Un which is verified on the wiki [http://elinux.org/RPi_VerifiedPeripherals#USB_WiFi_Adapters ].
    Also, I read on the wiki that someone has made a self-installer (so to speak) which should make it easy to impliment.
    Any thoughs before I go -out and buy this wireless adapter?
    PS: Should some add the other one to the problem adapter section.
    And as a side not, I think the problem may have been the confusion between the two chips (RT2770 + RT2720) somewhere in the software. or that the hub is not providing enough power and therefore this device is pulling power from the RPi.
    Just a though.
  • wallarug
    The two chips in this device are: Ralink RT2780F chipset with RT2720L as transceiver.  Does this mean anything driver wise?
    (I am still going to get a new adapter though)
  • wallarug
    wallarug over 14 years ago in reply to e14 Contributor
    Mr P wrote:
    i have had issues with broadcom on various laptops using different distro's of linux, this is the best solution i have found so far. i also cant confirm at the moment if the b43 firmware is in the repositories. i will check tonight and see if it is.
    i cant actually try this on the R-Pi as i dont have a USB wifi adapter with the broadcom chipset.
    http://ubuntuforums.org/showpost.php?p=10527475&postcount=5
    hope this helps.
    As you can see from the above posts, I don't think that it is a broadcom chipset.
  • wallarug
    How can I confirm the make if it is a generic brand?
  • GreenYamo
    Hello Fergus, although not an answer to the question directly above, have you had a look at the Adafruit distro for the Pi ? From what I remember reading, this has drivers built in for some wireless cards andf may be worth giving a go with your current usb adaptor ?
    Morgaine has posted in this forum with links to the distro.
    Trying to answer your actual question, have a look at the drivers that come with the adaptor (even if you have got it yet, you can normally find a web page that will supply you the drivers, hopefully from the place you are buying it from) for Windows, and they will give a fair idea. BE something like Drivers\windows\realtek or hopefully something equally as useful.
    Steve
  • wallarug
    I ahev the drivers, I just can't install them becasue I am a Linux n00b.image
    Could you help with this and this would solve my problem.
    Fergus
    See: http://www.raspberrypi.org/phpBB3/viewtopic.php?f=45&t=13482&p=143746#p143746 for files that I need help with.
  • wallarug
    Fergus
    Here is the instructions from the readme file that I don't understand/can't find the correct agruments to fill-in.  Could you PLEASE fill-in what I can't and then post back here.  please image.
              define the linux kernel source include file path LINUX_SRC
                         modify to meet your need.
    3> In os/linux/config.mk
              define the GCC and LD of the target machine
              define the compiler flags CFLAGS
              ** Build for being controlled by NetworkManager or wpa_supplicant wext functions
                 Please set 'HAS_WPA_SUPPLICANT=y' and 'HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=y'.
                 => #>cd wpa_supplicant-x.x
                 => #>./wpa_supplicant -Dwext -ira0 -c wpa_supplicant.conf -d
              ** Build for being controlled by WpaSupplicant with Ralink Driver
                 Please set 'HAS_WPA_SUPPLICANT=y' and 'HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=n'.
                 => #>cd wpa_supplicant-0.5.7
                 => #>./wpa_supplicant -Dralink -ira0 -c wpa_supplicant.conf -d
    4> $make
              # compile driver source code
              # To fix "error: too few arguments to function ¡¥iwe_stream_add_event"
                => $patch -i os/linux/sta_ioctl.c.patch os/linux/sta_ioctl.c
    5> $cp RT2870STA.dat  /etc/Wireless/RT2870STA/RT2870STA.dat
    6> load driver, go to "os/linux/" directory.
        #[kernel 2.4]
        #    $/sbin/insmod rt2870sta.o
        #    $/sbin/ifconfig ra0 inet YOUR_IP up
        #[kernel 2.6]
        #    $/sbin/insmod rt2870sta.ko
    7> unload driver
        $/sbin/ifconfig ra0 down
              $/sbin/rmmod rt2870sta
    7674.Makefile.zip
  • GreenYamo
    Hello Fergus, i'm afraid as I said above, i'm very much a Linux noob too, and other than looking like those instructions are for re-compiling the kernal with the drivers included (and even that is probably wrong) I can't help much image
    All I can say is that to get my USB stick working, I didn't have to do any this, just the instructions I posted a way back up this thread. I think there must be an easier way than doing the above.
