Raspberry Pi Forum Wireless network conectivity
  • Replies 75 replies
  • Subscribers 707 subscribers
  • Views 10221 views
  • raspberry
  • pi
  • wireless
wallarug
wallarug over 14 years ago
I bought one of these about 12 mths ago: http://www.jaycar.com.au/productView.asp?ID=YN8306&keywords=high+power+wireless+n&form=KEYWORD
I downloaded the drivers from the link above then installed them on a windows computer.  How do I use these linux drivers/installers on the raspberry pi to get the wireless adaptor to work?
Will this work with the Raspberry Pi?
  • wallarug
    wallarug over 14 years ago in reply to GreenYamo
    Thats ok.  but I found this site which looks interesting, I am posting it here so I can find it later image
    http://linux.die.net/man/8/iwconfig
    For fixing a file I messed up.
    http://elinux.org/RPi_Peripherals#Wireless:_TP-Link_TL-WN722N_USB_wireless_adapter_.28Debian_6.29
  • wallarug
    I bought the Edimax EW-7811Un but I need help setting it up, Steve, could you please help me with this one.  The RPi wiki says that it is verified but there is no guide to set-up this device for Raspbian.  I found this guide: http://www.ctrl-alt-del.cc/2012/05/raspberry-pi-meets-edimax-ew-7811un-wireless-ada.html but it has not worked for my RPi.  I think it has something to do with me not being able to get the rpi-update thing.  I tried to get this but failed.  Everytime I run rpi-update it returns:
    /usr/bin/rpi-update: line 1: syntax error near unexpected token `newline'
    /usr/bin/rpi-update: line 1: `<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Trans        itional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">'
    Can this be fixed so that I can update the firmware?
    Wireless card help would be nice as well image.
  • fustini
    fustini over 14 years ago in reply to wallarug
    I noticed from the link that Edimax uses the rtl8192cu driver.  I have another adapter (Asus USB-N13) which uses that driver and it did not work by default with the current Raspbian Wheezy image.  However, it did work ok with Adafruit's new image as it includes that driver, so you may want to give that a try: http://learn.adafruit.com/adafruit-raspberry-pi-educational-linux-distro/occidentalis-v0-dot-1
  • wallarug
    With the EDIMAX, it gives me the errors:
    8192cu: disagrees about version of symbol <name of part>
    8192cu: Unknown symbol <name of part> (err -22)
    The "name of the parts" are all different.
    What can be done to fix this issue?  This might sovle my problem.
    How do you unpack a .ko file?
    I didn't unpack mine.  this could be leading to the above issues.
    Message was edited by: Fergus Byrne
  • wallarug
    wallarug over 14 years ago in reply to fustini
    I do not really want to change image (right now).  But I might give it a go in the future.
    Right now though, I just want to get this adapter working. image
  • fustini
    My guess is that the 8192cu.ko module you have doesn't agree with the version of the kernel your running.  a .ko file is a kernel module file and shouldn't have to unpacked.  the utility "modinfo" will print out information about the module.  could you run that and paste the output?  also, could you paste what "uname -a" outputs?  it might be that the kernel versions don't agree.
  • wallarug
    will do image
    e14 Contributor over 14 years ago in reply to fustini
    Hey drew,
    I installed Occidentalis v10.1 successfully onto my Raspberry Pi's SD card and went to /etc/network/interfaces to add my SSID and password where it wanted me to add it. But for some reason I still can't connect to the Internet wirelessly when my wireless dongle is connected in (I'm using the Zyxel NWD2105 which uses Ralink firmware). When adding my SSID do I keep the quotation marks so it's SSID "xxxx" or do I remove the quotation marks? Is there anything else I must do to get my dongle working?
  • fustini
    fustini over 14 years ago in reply to e14 Contributor
    Hi Ahmad,
    I believe you should keep the quote marks.  An alterative to configuration via /etc/network/interfaces would be to wicd which is a GUI network manager that allows you to configure your wifi adapter.  You should be to install it by entering into the command line: "sudo apt-get install wicd" (while connected to Internet via Ethernet).  I wrote up more detailed instructions in this comment before:
    http://www.element14.com/community/docs/DOC-44703/l/raspberry-pi-wifi-adapter-testing#comment-15744
    I didn't try to install wicd it on the Adafruit image yet, so I think I'll give it a go this weekend.  I had installed wicd on the "official" Raspbian Wheezy image and it worked well.
    Cheers,
    Drew
  • wallarug
    Here's the output from uname -a:
    Linux raspberrypi 3.1.9+ #168 PREEMPT Sat Jul 14 18:56:31 BST 2012 armv6l GNU/Linux
    I also fixed the problem of the :
    ...by deleting the driver (8192cu.ko file).
    Which leads me to suspect that the RPi s/ware didn't like it.
    I can now also tell you that the output of lsusb is:
    Bus 001 Device 007: ID 7392:7811 Edimax Technology Co.,Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
    I hope this helps you solve my problem.  I also found someone who had the same problem and am reading what they did now: http://www.raspberrypi.org/phpBB3/viewtopic.php?f=26&t=6256&hilit=edimax&start=575
