We all know that there are people out there who are playing around with their little Pis (incl. me
). But who has the best overclocking configuration?
I don't mind if you have overvolted, but do tell us that.
Here is the 4 things that you can tell us that are in your config.txt file.
arm_freq=
core_freq=
gpu_freq= (or the other options for this config option such as h264_freq, v3d_freq, etc)
sdram_freq=
The best configuration I have found on the internet so far is:
arm_freq= 1150
core_freq= (not stated)
gpu_freq= 500
sdram= 600
over_voltage=8
My current configuration is:
arm_freq=932
core_freq=461
gpu_freq=350
sdram_freq=500
NO OVERVOLT
Let me define a stable configuration:
a. Your RPi starts up normally
b. You do not experince a 'crash' under normal operation
c. You have been running the configuration with minimial issues
d. You may only experience a crash or system failure due to external devices
WARNING: Setting any of the parameters which over volt your Raspberry Pi will set a permanent bit within the SOC and your warranty is void. So If you care about the warranty do not adjust voltage.
Who will have the best overclock???
