Raspberry Pi Forum Raspberry Pi as an Access Point.
  • Replies 29 replies
  • Subscribers 708 subscribers
  • Views 5859 views
  • access
  • raspberry
  • current
  • in
  • act
  • to
  • as
  • are
  • a;
  • these
  • my;
  • like
  • wireless
  • the;
  • point.;
  • settings
  • ;/etc/network/interfaces:
  • would
  • i
  • pi;
wallarug
wallarug over 13 years ago
I would like my Raspberry Pi to act as a wireless access point.  These are the current settings in /etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet static
        wireless-essid "wireless"
        wireless-mode ad-hoc
        wireless-channel auto
        address 192.168.12.1
        netmask 255.255.255.0
        gateway 192.168.12.2
#wpa-psk "robotics"
Any ideas how I can turn this into a dhcp server that can give out IP addresses?  I really am getting tired of changing to manual ever time on PC.
Any help will be apreciated.
  • recantha
    recantha over 13 years ago
    Hi.
    Take a look at:
    https://github.com/recantha/redwing-pi
    Under 'access_point' there are some scripts and config files which should help you to set this up, or at least work out what you're doing wrong.
    The scripts work for me on my Pi.
    Any problems/questions, please let me know. This will be the first time I've really publicised these scripts which are just a collection of set-up and config utilities that I use.
    Mike
  • wallarug
    wallarug over 13 years ago in reply to recantha
    Will look at later.
  • recantha
    recantha over 13 years ago in reply to wallarug
    Did you have any luck getting this to work?
  • wallarug
    Nope.  I will have to experiment with this tonight and see what I can get to work.  Right now, I think I need to re-image my SD card, I cannot use the device without the Wireless dongle plugged in (this is a problem).
    If anyone has any advice for setting this up, it would be appreciated.
    EDIT:  I remeber attempting to get this to work.  It was very compliated and I couldn't get it to work.
  • wallarug
    This link might help:
    http://www.recantha.co.uk/blog/?p=317
    Should do all the hard work for me! image
  • wallarug
    I have spent the last 5 hours working on this.  The file hostpda.conf only has support for a small number of drivers.  If someone could tell me how to get the 'rt2800usb' driver register, it would be much appreciated.
    Thank you.
  • wallarug
    HELP!!!!!
    I have it broadcasting but the device is not give out IP addresses?
  • wallarug
    I have successfully got the Raspberry Pi working as an access point but I have a few questions about different setups.
    http://sirlagz.net/2012/08/09/how-to-use-the-raspberry-pi-as-a-wireless-access-pointrouter-part-1/
    I used the link above which worked out nicely.
    Part One seems to do the trick for me...
    A. Raspberry Pi can be accessed through AP
    B. AP gives out IP addresses
    C. Devices can communicate between each other through AP (I tested between two windows machines Remote Desktoping into one of them)
    Part Two:
    If you want a wifi router, ignore Part 2, and go from this part straight to Part 3
    QuickLinks:
    I believe that this is if you DO NOT want to access the raspberry pi but attach it to a network. (PLEASE correct me if I am wrong)
    Part Three:
    How to make your RPi into a Router
    Now this is the bit that confuses me...
    If I can do everything that I listed above in Part One, doesn't that already mean I am routing data?
    Could someone please explain the benefit of Part three to me so I can decide if I need to follow the steps involved to improve my setup.
    e14 Contributor over 13 years ago in reply to wallarug
    Part 3 is if you want to use the Pi to route network traffic from one network onto a Wireless network hosted on the Pi.
    e.g. Network 1 (10.0.0.0/24) -> Raspberry Pi -> Wifi -> Network 2 (10.0.1.0/24)
    Part 2 is if you want to use the Pi to extend the network
    e.g. Network 1 (10.0.0.0/24) -> Raspberry PI -> Wifi -> Network 1 (10.0.0.0/24)
    There is no routing involved when packets go from ethernet to wifi.
    If you're still stuck, there's actually an image someone put together called Pi-Point
    http://www.raspberrypi.org/archives/2929
    It allegedly does excatly what you're trying to do.
