Raspberry Pi Forum Raspberry Pi as an Access Point.
  • Replies 29 replies
  • Subscribers 708 subscribers
  • Views 5802 views
  • access
  • raspberry
  • current
  • in
  • act
  • to
  • as
  • are
  • a;
  • these
  • my;
  • like
  • wireless
  • the;
  • point.;
  • settings
  • ;/etc/network/interfaces:
  • would
  • i
  • pi;
wallarug
wallarug over 13 years ago
I would like my Raspberry Pi to act as a wireless access point.  These are the current settings in /etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet static
        wireless-essid "wireless"
        wireless-mode ad-hoc
        wireless-channel auto
        address 192.168.12.1
        netmask 255.255.255.0
        gateway 192.168.12.2
#wpa-psk "robotics"
Any ideas how I can turn this into a dhcp server that can give out IP addresses?  I really am getting tired of changing to manual ever time on PC.
Any help will be apreciated.
  • wallarug
    wallarug over 13 years ago in reply to e14 Contributor
    Lawrence,
    I think I replied to you on the other forum...
    http://www.raspberrypi.org/phpBB3/viewtopic.php?f=36&t=31404&p=273543#p273543
    Jim,
    I had a look at Pi point but it DOESN'T Come setup to go as you think...
    It's had the Pi-Point stuff stripped out, too, to provide a pretty lean setup into which you can install what you need.
    So, You need to install all the software and stuff to get it working...
    I used this setup here: http://sirlagz.net/2012/08/09/how-to-use-the-raspberry-pi-as-a-wireless-access-pointrouter-part-1/
    Which is very good.
    e14 Contributor over 13 years ago in reply to wallarug
    Indeed you did image
    I plan on packaging up RaspAP into an easy to use SD card image with a web interface.
    Would you be interested in trying it out for me ?
    Cheers,
    Lawrence
  • recantha
    recantha over 13 years ago in reply to e14 Contributor
    I'd be interested in testing that for you, Lawrence.
    e14 Contributor over 13 years ago in reply to recantha
    Sounds good, I'm still writing up the Web interface but I'll post it up here when I finish it up image
    Getting there though, with the interface you'll be able to configure both the WiFi client details, and HostAPD as well image
    Fergus Byrne wrote:
    Jim,
    That is rather disappointing and I would think somewhat counter productive that the pi Point image had all the pi-point stuff stripped out of it.
  • wallarug
    Rather counter productive you would think...
  • wallarug
    What sort of web code will you be using?
    Also remember that it is the Raspberry Pi that would be running the web page... nothing to fancy image
    The main problem I am having with a  little bash script that I am writing is the three lines on the bottom of the /etc/network/interfaces file... They have something to do with the GUI interface (which I have never used due to lllaaaaaggggg on the Raspberry Pi.).  Can anyone inform me of how to remove certain lines from files please (using bash).
  • recantha
    recantha over 13 years ago in reply to wallarug
    Try using a text editor like nano or vi. Nano is easier to use.
  • wallarug
    wallarug over 13 years ago in reply to recantha
    I know how to remove them...
    Just how do I do it through bash script?
    Right now I bring up a nano session: sudo nano /etc/interfaces/network
    But I am sure there is a bash way.
  • mconners
    mconners over 13 years ago in reply to wallarug
    Normally the sh script way would be to make calls to sed and awk from your script and do in line editing that way.
    Here is an example:
    http://en.kioskea.net/faq/1451-sed-delete-one-or-more-lines-from-a-file
    Mike
