Raspberry Pi Forum Raspberry Pi as an Access Point.
  • Replies 29 replies
  • Subscribers 708 subscribers
  • Views 5804 views
  • access
  • raspberry
  • current
  • in
  • act
  • to
  • as
  • are
  • a;
  • these
  • my;
  • like
  • wireless
  • the;
  • point.;
  • settings
  • ;/etc/network/interfaces:
  • would
  • i
  • pi;
wallarug
wallarug over 13 years ago
I would like my Raspberry Pi to act as a wireless access point.  These are the current settings in /etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet static
        wireless-essid "wireless"
        wireless-mode ad-hoc
        wireless-channel auto
        address 192.168.12.1
        netmask 255.255.255.0
        gateway 192.168.12.2
#wpa-psk "robotics"
Any ideas how I can turn this into a dhcp server that can give out IP addresses?  I really am getting tired of changing to manual ever time on PC.
Any help will be apreciated.
  • mconners
    mconners over 13 years ago in reply to wallarug
    Another great example:
    http://quickleft.com/blog/command-line-tutorials-sed-awk
    Mike
    e14 Contributor over 13 years ago in reply to wallarug
    Fergus Byrne wrote:
    What sort of web code will you be using?
    Also remember that it is the Raspberry Pi that would be running the web page... nothing to fancy image
    The main problem I am having with a  little bash script that I am writing is the three lines on the bottom of the /etc/network/interfaces file... They have something to do with the GUI interface (which I have never used due to lllaaaaaggggg on the Raspberry Pi.).  Can anyone inform me of how to remove certain lines from files please (using bash).
    I'm using PHP with lighttpd
    Got it mostly working already image it's not too bad in terms of responsiveness, I'm hosting it on my Pi now image
    e14 Contributor over 13 years ago in reply to mconners
    Here's another way, just for fun and educational value:
    If you happen to know for sure that a file, call it foo, is 10 lines long,
    you can get all but the last 3 lines by doing:
       $ head -7 foo
    It's usually dangerous to rely on your file always being a fixed length,
    so you can find out how long foo is by doing:
       $ cat foo | wc -l
    You can combine these into a script that gets all but the last 3 lines
    of an arbitrary sized file by doing:
      $ z=`cat  foo  |  wc  -l`
      $ z=`expr  $z  -  3`
      $ head  -$z  foo
    I just remembered that the head command allows a negative argument to mean
    counting from the end.  So you could say simply:
        $ head  --lines=-3  foo
    to get all but the last 3 lines of file foo.
    (note that there is a double dash in --lines.)
    A few screenshots of what the configuration page looks like at the moment are on my blog at http://sirlagz.net/2013/02/06/script-web-configuration-page-for-raspberry-pi/
    Live demo at http://sirlagz.ath.cx:8880
    Though if you turn on hostapd, you will probably wreak havoc with my wireless haha
    Not very pretty but I'm working on the GUI image
  • wallarug
    wallarug over 13 years ago in reply to e14 Contributor
    What code are you using?
    html5? php?
    I'm using php on my Pi at the moment
    Just finished up doing the first version, very very messy though haha.
    Will upload it somewhere for you guys to try image
    Linky to the blog post - at the moment it's just the php script and supporting files.
    http://sirlagz.net/2013/02/08/raspap-webgui/
  • wallarug
    I was told that html5 (html+CSS+Java Script) is the way to go.
    I don't know why many people are not using this coding langauge.  I am going to start learning this langauge very soon and then see if I can host this on a websever running on the raspberry pi.  I will create something (I don't know what) and let you know how well it works (IN THE DISTANT FUTURE).
    I wish you the best of luck with your project and I will be following it intently.  I like the idea of a GUI setup for hostapd and wireless.
    I haven't looked into html5 much as I'm already familiar with php.
    I may look into porting it over to html5 later though.
