Raspberry Pi Forum Raspberry Pi Ethernet Problem
  • Locked Locked
  • Replies 30 replies
  • Subscribers 707 subscribers
  • Views 18495 views
  • raspberry
Whenever I turn my Raspberry Pi on, the three network lights just blink and it can't connect to the internet. I have checked all network items and they do work so it comes down to the Raspberry Pi.  Is there something physicaly wrong with the board itself?
It is Model B and I have Wheezy installed on the SD card if that helps or makes a difference at all.
    shabaz over 11 years ago in reply to e14 Contributor
    I'd check a few basics:
    1. Eliminate the hub (surprised these are still available) and plug directly into your home router's switch ports (usually there are about 4 ports on the LAN side, plug into one of them)
    2. Try a different Ethernet cable, in case it is faulty marginally and allows the link to come up but not communicate
    3. Turn off/on your router in case it really can't assign an IP address for some reason (could be a faulty router)
    e14 Contributor over 11 years ago in reply to shabaz
    Hi shabaz. Not sure if I mean hub or router but whichever, you were right, that was the cause of my problem. Realised this shortly after placing my message when everything else in the house lost internet connection.
    Turning hub/router on and off (with the 30 second pause) fixed the problem.
    Thanks for your help.
    Excellent, glad it is resolved!
    Hello Eric I am facing great problem in raspberry. I need to make my raspberry pi as a hotspot device. For this i am using so many links but i am unable to this task.
    I am posting the same link from where i am taking help.
    Hotspot – WiFi Access Point | Raspberry-at-home.com – Your ultimate source of Raspberry Pi tutorials (WiFi, 3G, XBMC, Su…
    I will be so glad if u give me any type of assistance....
    Waiting fr ur reply.....
  • ktjr
    ktjr over 9 years ago in reply to e14 Contributor
    I could not see eth0. and it is disabled since yesterday only before it was connected. How to enable this. Please help resolve this issue. Thanks in advance
  • drifter1693
    drifter1693 over 8 years ago in reply to e14 Contributor
    Can I use mobile hotspot as a router
  • limerasy
    limerasy over 8 years ago in reply to e14 Contributor
    If it's still useless, get a new one
  • colporteur
    colporteur over 8 years ago in reply to e14 Contributor
    Give credit to Shabz providing me this link for establishing an AP. I used the instructions and had success in getting it to work.
    https://learn.sparkfun.com/tutorials/setting-up-a-raspberry-pi-3-as-an-access-point
    Sean
    e14 Contributor over 3 years ago in reply to colporteur
    [deleted]
  • colporteur
    colporteur over 3 years ago in reply to e14 Contributor
    Glad to hear. Shabz's gift of knowledge keeps on giving. Wow, that was four years ago and I'm looking at using the same solution again. Thanks for the knowledge link, I forgot I had it.
