Raspberry Pi Forum New Raspberry Pi Model B+
  • Replies 30 replies
  • Subscribers 712 subscribers
  • Views 5134 views
  • raspberry
  • pi
  • b_plus
  • model
4 USB ports, microSD (push release type), new form factor, no RGB (J7 labeled as A/V  ???), no Link/FXD/100 led's (maybe integrated in magnetic's), same ram (512mb), display, camera connectors and 40 pin header.
Raspberry Pi Model B+ V1.2
http://www.zlham.geek.nz/images/news/rpi-b-plus.jpg
http://www.zlham.geek.nz/images/news/rpi-b-plus-close.jpg
Don't shoot the messenger.
    mcb1 over 12 years ago in reply to mcb1
    Some more pictures with my copyright.
    Pity I forgot to take the tripod ...sorry.
    Oops the PiFace Digital isn't going to work like this.
    It may need an extension socket.
    ChipKIT Pi works but might require something on the USB to prevent shorting out.
    Rubber buffer still works on the Ethernet
    GertDuino probably could do with a lower buffer.
    Wyolum Alamode clears, but again some insulation on the USB wouldn't go astray.
    SleepyPi clears, but you might lose some of the prototyping area.
    I would add some insulation on the USB just to be sure.
    Sparkfun RaspiRobot has plenty of clearance due to the double socket
    PiCrust was the same and the relocated Display socket is still accessible
    PiRack not all the pins work, but clearance isn't an issue.
    One other thing that seems to have missed the headlines.
    The B+ comes with FCC Class B certification which means its suitable for residential applications.
    shabaz over 12 years ago in reply to mcb1
    You have a LOT of daughter cards : ) I've just got a Sleepy Pi from Jon W.
    Oh, and a few XMOS boards.
  • Problemchild
    Problemchild over 12 years ago in reply to mcb1
    Yes the Pi Rack is the best Idea to lift a board or two away from the RPI the only problem is that the best way of using it is as you put it here, on it's side, vertically it  tends to flop all over the place image
  • kingrahl
    kingrahl over 12 years ago in reply to Problemchild
    Would single or double sided foam tape be a good buffer between the USB and any board? Are there any concerns where that might be a bad idea?
    mcb1 over 12 years ago in reply to kingrahl
    I think something more durable would be better.
    You might want to use a piece of thin plastic often found as the clear cover on bound folders, and use the double sided foam to stick it to the USB.
    Obviously its not going to work for PiFace Digital, but will for the others.
    mark
    Hello everyone!
    Just a short question:
    Is it now possible to connect a 3.5 microphone to the Raspberry Pi Model B+ or do I still need a Wolfcard or a USB to mic connector?
    Thx.
    Greets for Munich, Max
  • Problemchild
    Problemchild over 12 years ago in reply to e14 Contributor
    The hardware is essentially the same between the B &b+ so no you can not, you will need an external sound card of some type.Check for fitting before hand or have a riser like Mark used
    e14 Contributor over 12 years ago in reply to Problemchild
    Thanks @John Alexander.
    I don't have the B+ yet but the model B. Can anyone recomment a good usb to mic connector?
    Thx
  • Problemchild
    Problemchild over 12 years ago in reply to Problemchild
    Re the sound card, if you don't have a preference already how about a simple USB sound card with Mic input?
    The Wolfson card is very hi quality so it may be good if you really need something good...All depends on you.
    Remember you will need to lift the card up  on the B+
